Go to Post Without programmers there would only be a robotic beauty contest. - mallot1243 [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 23-02-2013, 00:41
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
255.0.0.0 or 255.255.255.0?
So I've heard teams using both of these subnets. Does it matter which you use, and if so, which one is the specific?
Unread 23-02-2013, 00:49
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: 255.0.0.0 or 255.255.255.0?
Via the document at http://wpilib.screenstepslive.com/s/...or-competition :
When operating at home, everything will work fine with the Driver Station set to a subnet mask of 255.255.255.0 and any IP in the 10.TE.AM.ZZ range. At the competition, the DS IP must be 10.TE.AM.5 and the subnet mask must be set to 255.0.0.0 to work properly with FMS.
So for use with practice settings (ie, direct connection) it needs to be 255.255.255.0, but at competition it needs to be changed to 255.0.0.0
See you in Raleigh!
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 23-02-2013, 00:52
Lead Programmer
See you in Raleigh!
Thanks! Really clears things up!
Unread 14-03-2013, 18:54
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
I'm kind of late here but from what I know a 255.0.0.0 subnet mask works for practice as well. There is no need to mess with it.
Unread 17-03-2013, 09:54
dsherw00d dsherw00d is offline
FRC #0378
dsherw00d is a jewel in the roughdsherw00d is a jewel in the roughdsherw00d is a jewel in the rough
255.0.0.0 is a larger host (computers, cRIO, Cameras, D-Link, etc) network which includes the hosts in 255.255.255.0. Competitions use 255.0.0.0 because they need more hosts. They run a flat network - all hosts are 10.x.x.x and with a 255.0.0.0 mask - they are all in the same network. All teams can technically communicate with each other and with FMS. This is why 255.255.255.0 still works, but your devices can only communicate with devices in 10.TE.AM network - just your team network - at least without a router.
You can use either one outside of the FMS system. It's easier to stick with 255.0.0.0 at all times.
IP Sub-netting is a great thing to know if you are interested in IT, Network Engineer, etc. http://en.wikipedia.org/wiki/Subnetwork . I'm a little rusty at it. There are many iPhone/Android apps for IP sub-netting.
Unread 17-03-2013, 16:54
NeatNit's Avatar
Alumni Programmer
Must... Not... Click... Must... Sleep.... NO!!!!
