Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 23-02-2013, 12:13
DeadlyJohny DeadlyJohny is offline
FRC #3417
DeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to behold
Basic Programmer. What am I doing wrong?
Hey guys! Thanks! I'm using a friend accounts but i'm not sure what I am doing wrong. I have programmed all the buttons and the throttle to control their motors and it all seems right. But when we ran the code last Monday, only drive motors turned. All the other motors ran on baije jaguars. Could that be it? I know the PWM's are right and the jaguars do have power and flash yellow. What is wrong?
Thanks in advanced!
http://i.imgur.com/36mr4Gw.png?1
Unread 23-02-2013, 12:23
Re: Basic Programmer. What am I doing wrong?
Your code seems fine.
Yellow flashing on the Jaguars while the robot is enabled means they aren't receiving a PWM signal.
Even if your code logic wasn't correct, the Open statements for PWMs 7-10 would give you solid yellow Jaguar lights (while Enabled) if the control wiring was correct.
The problem can be split into code vs hardware by using the Test mode on the Driver Station and the Test tab on the Dashboard. The default Dashboard gives us control over each individual motor, while bypassing all our custom code except for the Device Opens.
Some suspects are:
  • PWM cable connection on the Jaguar - pins not inserted at the right angle or cable orientation (black wire to the inside)
  • PWM cable connection on the Sidecar (black wire to outside)
  • 12v power to the Digital Sidecar (3 bright green power lights on Sidecar)
  • The 37-pin ribbon cable to the Sidecar - check that it's securely plugged in at both ends and test eact pin for continuity (can swap in commercial cable if you have one)
  • The Digital Module connection to the cRIO Chassis (pull the module and inspect for bent/broken pins, metal debris)
Unread 25-02-2013, 13:57
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Don't forget the PWM cable itself! We've had issues this year with faulty PWM cables, particularly splitter's.
Unread 25-02-2013, 17:12
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
This year we've had like 17 thousand problems with PWM
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
