Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 23-02-2013, 20:07
Baldwin Robotic's Avatar
Baldwin Robotic Baldwin Robotic is offline
FRC #2439
Baldwin Robotic is an unknown quantity at this point
Power distribution board problems
Our power distribution board doesn't light up the 5 volt light. We tested the voltage and it wasn't reading 5 volts either.
Dose this mean we have a bad/broken board?
Unread 23-02-2013, 20:09
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Power distribution board problems
Possibly. Where were you testing the voltage? At the connector, or at the wire?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 23-02-2013, 20:22
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Could be a bad power distribution board or it could be something is shorting out the 5v line. Make sure there's no metal flakes inside the connector and that nothing is connected to 5v when you measure it. Once that's checked out if the problem persists it is probably a bad power distribution board.
Unread 23-02-2013, 20:45
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
We had the same problem.Disconnect things one at a time and see which wire is the culprit
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 23-02-2013, 20:53
If the BAT and 6V LEDs are lit but the 5V LED is not, there are three reasonable possibilities.
The most common cause I've seen over the past few years is a sensor switch connected to the wrong Digital I/O pins, connecting the (-) pin to the 5V center pin instead of to the SIG pin on the other side. That shorts the 5V power, and the supply on the Digital Sidecar shuts down to protect the wiring. Disconnect everything from the Digital Sidecar and see if 5V comes back. Then reconnect things one at a time, and see if any of them causes it to fail. If you find the offending circuit, track down what's wrong with it.
The second likely cause is a bit of metallic debris among the DIO pins, also shorting 5V to (-) and causing the supply to shut down. With everything unplugged, use a strong flashlight to inspect the pins for anything that might be a problem.
The remaining possibility is a faulty Digital Sidecar. After you've eliminated the other options, then replacing it is a good thing to do.
[edit]Whoops, I misread which board was under consideration. I think my advice is still good, just not in this context.[/edit]
Unread 23-02-2013, 22:17
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
When in doubt, switch it out! I think that's the best way to figure out what's going wrong. If a new one works, mark the other as second rate and move on.
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 23-02-2013, 22:31
On the other hand, if faulty wiring is to blame, you might just fry every sidecar you install before you find the real problem. And since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting.
Unread 23-02-2013, 23:13
Sounds like he's talking about the camera 5v connection, rather than the Digital sidecar.
If you are talking about the 5v wago (normally power for the camera), then if you aren't getting power from it, it has probably blown it's fuse.
Of course you can get another 12v-to-5v converter and just power the camera through it off a regular 12v output.
There's nothing real special about the 5v power on the Power Distribution board.
But you do want to figure out why it blew before you do it again.
Unread 23-02-2013, 23:22
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
We too had the same problem with two PD boards. On one the 5 volt camera output didn't work, and on the other the 24 volt output (for the cRIO) didn't work.
If you want to look at the schematic for the PD board, go here, click "Power Distribution Board", then click "Power Distribution Board Circuit Design". Thank you 3992 for the schematic!
Hope this helps,
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 24-02-2013, 11:18
There are a few things that can go wrong on the PD. Most are due to abuse. A hard drop can shake one of the larger components loose from the board or a short on one of the power supply lines can cause the current limit device to fail. You can repair the board under
R65 M. Devices may be repaired, provided the performance and specifications of the component after the repair are identical to those before the repair.
Be prepared that the components are surface mount and that requires a little experience to repair and replace. It is also possible that metallic debris has entered the PD and it needs to be cleaned. The PD is easy to open when it is not on the robot.
