Go to Post Maybe it just seemed like five hours...I had freshmen in my vehicle! - Qbot2640 [more]
Unread 24-01-2003, 18:32
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Inverse Tangent
I need to know how to do this on the RC. We need to find the angle of the joystick from the X and Y variables only. Normally arctangent is what would be used. But the RC doesn't provide this function. Options?
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
Unread 24-01-2003, 18:35
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
You could do a Talyor approximation or something. There's been discussion on this already.
Return of the Inverse Trig Functions explains arcsine and arccos.
Adler Attack #933 -- Trigos
Unread 24-01-2003, 19:38
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
We have the answer...
We (team 159) have just finished coding our tranlational drive routine. This does just what you want, figuring an angle from joystick values. Although it uses two joysticks, it can easily be adapted to one. The source will be posted later tonight, in the white papers section
Unread 24-01-2003, 22:45
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Damian,
Just a suggestion. If you place your subroutine outside of your main loop then you can get rid of the GOTOs.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 24-01-2003, 22:49
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
My team is using the inverse tangent function for a different reason... We've settled on an approximation formula (at most 1/2 of a % error). We may or may not decide to run this in the custom circuit. If you PM me, I'll get the approximation. It's a 3-part piecemeal function. Only uses the four basic operations
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 24-01-2003, 23:30
Cipher X's Avatar
Cipher X Cipher X is offline
no team (Former SigmaC@t Member)
Cipher X is an unknown quantity at this point
Send a message via AIM to Cipher X
Sin Function
sin x = 16x (p - x)/[5p2- 4x (p - x)]
x = 0 formula = 0.00000 sin x = 0.00000 error = 0.00000
x = p/20 formula = 0.15800 sin x = 0.15643 error = 0.00157
x = p/10 formula = 0.31034 sin x = 0.30903 error = 0.00131
x = 3p/20 formula = 0.45434 sin x = 0.45399 error = 0.00035
x = p/5 formula = 0.58716 sin x = 0.58778 error = -0.00062
x = p/4 formula = 0.70588 sin x = 0.70710 error = -0.00122
x = p/10 formula = 0.80769 sin x = 0.80903 error = -0.00134
x = 7p/20 formula = 0.88998 sin x = 0.89103 error = -0.00105
x = 2p/5 formula = 0.95050 sin x = 0.95105 error = -0.00055
x = 9p/20 formula = 0.98753 sin x = 0.98769 error = -0.00016
x = p/2 formula = 1.00000 sin x = 1.00000 error = 0.00000
If found that on the internet and it is pretty accurate.. there are some stuff with approximation series but i couldnt get it to work right, but this seems to work very well. The formula which is amazingly accurate and use of the formula leads to a maximum error of less than one percent
And PS this formula was first discovered by this indian guy named Bhaskara I in 629 AD.
Now all u got to do is find a formula for Cos and ur set lol
Cipher X
"Whatever you do will be insignificant, but it is very important that you do it."
-Mahatma Gandhi
Unread 24-01-2003, 23:52
Cipher X's Avatar
btw the last post has nothign to do with arctan well it might but not a useful on but i thought someone might use it for somehting so....
-Mahatma Gandhi
Unread 25-01-2003, 00:05
Cipher X's Avatar
ArcTan
I did some searching and found this http://www.mcs.surrey.ac.uk/Personal...pi.html#arctan
arctan( t ) = t – (t^3)/3 + (t^5)/5 - (t^7)/7 + (t^9)/9 - (t^11)/11 .........
-1< t < 1
I tried it out its pretty close to what the real value is
x = tan (.5)
arctan(x) should equal .5
x – (x^3)/3 + (x^5)/5 - (x^7)/7 + (x^9)/9 - (x^11)/11 = 0.4999763883
But Surprisingle enough
x – (x^3)/3 + (x^5)/5 - (x^7)/7 + (x^9)/9 = 5.000939788
The More terms you do the more accurate your answer is
!The only problem you might run into in pbasic is memory and speed!
Cipher X
-Mahatma Gandhi
Unread 25-01-2003, 00:43
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
Haha. Inverse Trig - all too familiar to me. We thought about using it for our robot project (check link below), but after searching through the ChiefDelphi forums, we opted against it. Its way too complicated and difficult for BASIC, and it just wasn't worth the effort for our project. Remember that if your program takes too long to run, your robot cuts out, so that may be a slight concern. See if there's some simpler solution. Inverse Trig, BASIC, & Binary Radians don't mix very well.
www.team102.com
2000 National Finalists
2003 J&J Mid-Atlantic Regional Winners
2003 BattleCry Best Autonomous
Unread 25-01-2003, 15:25
I would do a lookup table (in EEPROM) with whatever function you need.
Reading from the EEPROM is much faster then doing a bunch of complicated (or even not so complicated equations)
Unread 25-01-2003, 22:24
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
There SHOULD, theoretically, be a very easy way to do inverse tan in PBASIC... I'll post more if my code actually works. ;-)
