Go to Post -dave "The Circular Saw of FIRST" lavery - dlavery [more]
Unread 24-02-2013, 11:55
Re: Balancing a Pneumatic wheel
Originally Posted by Justin Shelley View Post
I think if the weights will work on sport bikes that they will be fine on a robot wheel a 2006 yzf r6 has a top engine rpm of around 21,000RPM. The sixth gear reduction ratio is 1.074. Dividing 21,000RPM/1.074 will produce the RPM of the rear wheel. This comes out to be 19,553RPM. I don't think the shooter wheel is hitting that speed lol Now i realize you may do the math and realize nobody ever drives that fast
That's well over 1200 miles per hour. I don't think the wheel itself would survive, much less stick-on weights.
but when the bike is doing 250MPH, people do drive that fast on the track, the rear wheel is spinning at abut 3,703RPM which is faster then any shooter wheel is spinning. So Andrew you are just fine using wheel weights
Based on reports I've seen here, some frisbee shooters are spinning their wheels at 6000 RPM or higher. 5000 RPM seems common. Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself.
Unread 24-02-2013, 14:59
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
I believe those are the smaller wheels, not the pneumatic. If someone is spinning that pneumatic wheel over 4,000 RPM then the are lucky they still have a wheel.
