Balancing a Pneumatic wheel
We've got 2 6" Andymark pneumatic wheels on our shooter, and we were having some major issues with vibration due to the air spigot throwing off the weight distribution. We removed the innertubes entirely and filled them with bubble wrap which helped some, but it still vibrates badly because the tire doesn't seat particularly well without inflation. For teams that are using pneumatic shooter wheels, what did you do to balance them?
Also, did anyone find a different type of wheel to be superior? |
Re: Balancing a Pneumatic wheel
We are using a single 8" pneumatic wheel and the team taped a few small nuts/bolts into the spoke opposite of the filler tube. Works fine.
We were running the tire without an innertube but discovered it flattened out too much and it was difficult to get a good grip on the disk. |
We used 1/4 oz tire weights from Harbor Freight - they're adhesive backed and worked like a charm!
Two long bolts on the holes opposite of the air nozzle, with washers stacked on them. Our sweet spot was 9 washers on each bolt, give or take a few for others depending on bolts/nuts and such.
Am I the only one that watches lunch with Andy? |
Step 1: Take the inner-tube out.
Step 2: Fill the tire with pool noodle which has been cut in half. Step 3: Thank your friendly M'Aiken Magic mentor from South Carolina. Works like a champ, promise. |
Seriously, don't forget to take into account that these wheels are running at speeds they were NOT designed for. Make sure anything you attach to them can handle the speeds. |
#7
Do what we did: Just take the tubing out! Literally. Just the hub and the rubber tire. No inner tube. It works beautifully.
#8
When you couple the strong adhesive and with the centripetal force of the wheel, there's no way these puppies will fly off. |
#9
I know team 3130 removed the whole inner tube and replaced it with pool noodle and had great success with it.
#10
a 2006 yzf r6 has a top engine rpm of around 21,000RPM. The sixth gear reduction ratio is 1.074. Dividing 21,000RPM/1.074 will produce the RPM of the rear wheel. This comes out to be 19,553RPM. I don't think the shooter wheel is hitting that speed lol Now i realize you may do the math and realize nobody ever drives that fast but when the bike is doing 250MPH, people do drive that fast on the track, the rear wheel is spinning at abut 3,703RPM which is faster then any shooter wheel is spinning. So Andrew you are just fine using wheel weights ![]() |
#11
The wheels are well balanced (though there is still enough vibration to matter) and there is a shield in place to keep debris from flying out if something comes apart at speed. |
