Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 24-02-2013, 14:08
Re: Gyro - Running robot code from laptop issue.
I don't seem to have any problem.
I just ran a test and the gyro is responding properly after a run-re-run.
Anything else that might be a contributing factor?
Unread 24-02-2013, 16:40
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I am sure there is....
We can run the example code just fine, stop, restart.
We put our drive straight.vi in teleop in a robot project and tested, and that is where we have the issue. We spent the day testing all of the gyros, and analog cards yesterday, and everything was in working order.
Thanks for looking into it, love the website, it is my goto for anything electrical.
The sooner we get behind schedule, the more time we have to catch up.
Unread 24-02-2013, 17:28
The likeliest possibility I can think of is that the robot isn't left to sit still long enough the second time through to allow the gyro to initialize and establish a zero movement point.
I should have addressed the matter of Finish.vi, since you asked and you say such nice things.
Normal robot operation/termination never goes through Finish.vi.
The power just gets cutoff and the code ceases mid-execution.
The Stop sign on Robot Main functions the same way.
That big "Finish" button in Robot Main is the only way that Finish.vi ever gets executed.
Unread 24-02-2013, 20:24
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Well, I guess I'll say some more nice things... your cute too.
But the robot was not moving, we had it on "stilts", that is what the kids call it, when we have it on 2x4's so the wheels don't touch the ground.
We will keep digging tomorrow. Thanks for the info on the big finish button, I was told this leaving the code hanging with the stop button, is sometimes a problem, by someone that uses Labview everyday.
I understand much of the control code, and understand labview, but stuggle with many things in Labview itself, I am a PLC guy by trade..
Thanks again.
Unread 24-02-2013, 22:24
The Stop button can be a problem in the commercial world for the same reason we bother with teaching the students to close opened devices in Finish.vi.
When the students move on from FRC and run into LabVIEW later in college or in the working world, some classes of peripheral devices must be shutdown cleanly or they won't initialize properly when LabVIEW is later reconnected to them. FRC just doesn't happen to use any data acquisition devices that are susceptible to that.
Finish.vi is there to teach them good habits even if it doesn't fit our particular use case.
Unread 25-02-2013, 10:19
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Mark,
Do you think it could be that the code is given the "reentrant" property? I am not sure if I spelled that correctly, but the property where labview will spawn a new "object" each time the vi is called, so you can have multiple sub.vi's in the code, and they will not interact with each other?
Just trying to think about what the issue may be.
Scott.
Unread 25-02-2013, 11:17
Being called from a reentrant vi shouldn't affect the Gyro Get.
It's still just operating on the device reference given to it and simply reading the counter published by the FPGA.
If you have a simple case that repeats the problem someone could take a look at it for you. I have a small window to look today, but I'll be volunteering or attending events with my team after today.
Unread 25-02-2013, 19:24
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
My son just told me that I have stated this wrong, it is not when the code is stopped from the programming laptop. The issue is when the drivers station is enabled, the data is good, and after the drivers station is disabled, and then re-enabled without stopping the code on the programming terminal, the second time the gyro data is not reliable.
Does this change anything? Thanks again.
Sorry.
Unread 25-02-2013, 19:41
Does it depend on how long the code/robot is disabled? The errors will accumulate over time, and restarting the code will calibrate again. If the error is caused by running the code for five or ten minutes while the robot is disabled, then yes, I think that explains it to me. If it happens for a disable of a few seconds, then it doesn't.
Greg McKaskle
Unread 26-02-2013, 07:32
If it's happening while Disabled, then you can read/display the gyro in the Disabled.vi to watch it while it goes awry. I imagine the center point calibration is off kilter. There are some calibration options on the Gyro Open that you can tinker with.
Disable only stops motor/Relay outputs, everything else keeps running, including the gyro.
Maybe it'll be enlightening.
