Go to Post Don't give FIRST ideas...we like our 45 day build season. They can make it shorter. Never underestimate the power of the GDC. - Littleboy [more]
  #32   Spotlight this post!
Unread 24-02-2013, 14:59
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Re: Balancing a Pneumatic wheel
Originally Posted by Alan Anderson View Post
Based on reports I've seen here, some frisbee shooters are spinning their wheels at 6000 RPM or higher. 5000 RPM seems common. Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself.
I believe those are the smaller wheels, not the pneumatic. If someone is spinning that pneumatic wheel over 4,000 RPM then the are lucky they still have a wheel.
