Go to Post So as you're thinking about this, think simple. - Cyberguy34000 [more]
Unread 24-02-2013, 15:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Fun Fact
Originally Posted by Greg McKaskle View Post
Equally fun fact:
When you compare anything and one of the elements is NaN, the result is false. Nan > 0 is false and Nan < 0 is false and Nan == 0 is false.
And it isn't just LV. This is what IEEE 754 says to do. And it makes sense, but at the same time will surprise you at times when you least expect it -- possibly causing shooters to misbehave, wormholes to form, etc.
Greg McKaskle
Corollary: The smart programmer uses this fact to some advantage. If there's a possibility of you getting a NaN as result, then make sure your false case is what you'd want to run if you're processing a NaN. Makes things a lot more reliable.
