Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 24-02-2013, 17:27
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Balancing a Pneumatic wheel
Here's how I did it:
I also used stick on lead weights for RC airplane balancing, but I simply did not trust just double sided sticky tape to hold them inside the wheel.
I stuck the weights on where they needed to go and then I used 30 minute epoxy as the final balancing "weight". This also helps to secure the weights in place.
http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML
The fourth picture is what happens after you spend time balancing the wheel and the tire decides to spin the tube inside the wheel resulting in an unbalanced wheel...
ID:	14164  Click image for larger version
ID:	14165  Click image for larger version
ID:	14166  Click image for larger version
ID:	14167  Click image for larger version
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 24-02-2013, 17:38
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by ksafin View Post
When you couple the strong adhesive and with the centripetal force of the wheel, there's no way these puppies will fly off.
What centripetal force? In the rotating frame of the wheel, there is a centrifugal force, which tends to push the weights away from the center of rotation. It's working against you, not with you. I don't know what adhesive you're using, but I would feel safer if you have a cover over your shooter wheels.
We used nuts and bolts, with various amounts of washers, at up to three points around each wheel. And a cover over the whole shooter assembly.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 24-02-2013, 17:44
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
My apologies, I meant centrifugal.
I don't know how this works against us though.
Considering our weights are on the very outer edge of the plastic hub, pushing them outward away from rotation keeps them more solidly in place.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 24-02-2013, 17:53
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
And also flying out of the wheel, into the limbs of other people.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 24-02-2013, 18:01
Andrew Lawrence
Posts: n/a
Introducing the 2014 FRC game....
Unread 24-02-2013, 18:09
ksafin's Avatar
AKA: Kirill Safin
Let's talk more about the feasibility of it than joking around about it.
I don't see a way for them to fly out.
Unread 24-02-2013, 18:33
Gregor's Avatar
I wasn't joking. I would never trust adhesive on a high rpm flywheel. If it isn't good enough to hold on bumpers, why is it good enough for a shooter?
<Since 2011
Unread 24-02-2013, 18:36
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
To be honest, why not put the wheel on a shaft between a pair of bearings? It takes almost all of the imbalance out of the system. Try McMaster 5913K71 bearings for 1/2" shafts...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 24-02-2013, 18:49
ksafin's Avatar
AKA: Kirill Safin
For one, I can't even pull the weights off with my bare hands. It's a pretty tough adhesive. I need pliers to even come close to tearing them off.
For two, the centrifugal force of the wheel keeps them lodged. I don't see any way for them to come out when you pair the two of these together.
Imagine being on a gravitron, except also being taped to your seat with a super strong adhesive. Are you going to get anywhere?
Unread 24-02-2013, 19:03
AKA: Bradley Rigdon
Regardless of how you balanced your tire it is possible for anything to fly off including bolts with washers used for balancing or even the whole wheel so shield your spinning items if possible to protect from flying objects.
BTW tire shops use adhesive weights for balancing car tires.
http://solutions.3m.com/wps/portal/3...beMJV74VR9N7gl
Unread 24-02-2013, 19:10
Andrew Lawrence
Posts: n/a
No. Such. Thing.
Unread 24-02-2013, 19:18
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Originally Posted by Andrew Lawrence View Post
No. Such. Thing.
While that's technically true, it's a convenience term for the outward force component of rotational inertia. It exists for the intents and purposes of describing and calculating behavior. You got his point
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 24-02-2013, 19:54
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Has anyone looked into Dyna Beads?
There used mainly for balancing motorcycle tires. Should work for us.
http://www.innovativebalancing.com/index.php
Here is a Youtube video showing how they work.
http://www.youtube.com/watch?v=eq263AYgyYg
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 24-02-2013, 20:15
ksafin's Avatar
AKA: Kirill Safin
No. Such. Thing.
Not an actual force, but you understand exactly what I'm saying and the concept I'm referring to.
Unread 24-02-2013, 20:29
Best Available Data
FRC #1778 (Chill Out!)
No. Such. Thing.
I do not think responses like this really add anything to the discussion at hand. If you wouldn't phrase it that way when talking to your grandmother, it probably isn't the way you want to say it on CD.
As others have said, it is certainly a physics concept and being able to explain the difference between centripetal and centrifugal force is a key indicator that you understand what a reference frame is, and how they work. In college, particularly in Orbital Mechanics or Mechanism design this intuitive understanding becomes very important as the vector math gets real crazy, real quick. Any good physics textbook should have a reasonably in depth explanation, an old xkcd comic does a decent job in a blurb, and of course Wikipedia goes into much more depth.
