Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
Unread 24-02-2013, 21:15
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Is there a speed sensor input example for Labview?
We are using a banner sensor, (very similar to AB, just smaller packaging, and polarized) two pieces of reflector tape, on a vex hub. We have sized the tape so it is 90 degrees on, 90 degrees off.
We are using the same code that was posted, and but averaging over two samples to balance any, not quite 90 cuts, on the reflectors.
This is giving solid RPM measurement. We are controlling with "take back half" controller, posted by 123 last year.
Our target speed is 3700, and max speed of 4400 on the wheel. We have confirmed the speed with a handheld optical tachometer. We come to speed in about 2.8 seconds, and can hold a +- 3% to shoot.
We tried bang bang, but the counter resolution was fighting with the motor update cycle. I realize now the problem was the RPM calculation, with the low resolution "encoder" we could really only calculate RPM's in steps of 300 RPM's. TBH is working, so we are working on things that aren't but when I get time we will go back and try bang-bang with rpm calculated as period in lieu of counter, to see the real comparison.
The sooner we get behind schedule, the more time we have to catch up.
