Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 24-02-2013, 21:41
pigpenguin's Avatar
pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Java compile issues
Alright so I have run into a small problem with my latest development of code.... when I go to deploy it to our test robot it goes through the same steps it always has except it goes crazy when it hits some of our math functions namely the arc trig functions. As far as I can tell it is using an old version of java (netbeans says its 1.3) so I am curious... does the robot have to run such an old version of java or is my computer doing something weird where it is pointing it to an old version? any thoughts would be greatly appreciated.
"Insanity isn't a plea its a way of life and here we are all one card short"
Unread 24-02-2013, 21:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Java compile issues
Yes, the wpilibj plugins are stuck in 1.3. There are a variety of reasons for this, mainly that vxworks on the CRIO is old. All you really need to know is that your stuck with 1.3, so no enums, generics, etc.
All opinions are my own.
Unread 24-02-2013, 22:14
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Alright that makes sense (bit annoying but eh) so now I am trying to work out how to do some of these functions so I went to look through the javadocs for 1.3 (the one I found was here: http://docs.oracle.com/javase/1.3/docs/api/index.html) and it seems to suggest that math does have these functions (http://docs.oracle.com/javase/1.3/do...lang/Math.html) any idea why the compile still wouldnt be able to find them?
Unread 24-02-2013, 22:47
The cRIO runs JavaME, which is a subset of JavaSE 1.3, so even looking at the JavaSE v1.3 docs isn't sufficient.
There are additional math functions that aren't in the java ME spec that are implemented in com.sun.squawk.util.MathUtils. This is in addition to the required JavaME math functions in java.lang.Math
What functions are you looking for?
Unread 24-02-2013, 23:40
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
thank you so much for pointing that out... we were half way through writing our own using taylor series saved us a whole lot of time.
We were looking for arc tan, arc sine, and arc cos
