Go to Post A winning robot is the better robot, no matter how it was made or how much it cost. - Chris is me [more]
Unread 24-02-2013, 15:40
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Autonomous Moving Backwards
Can you guys help me with making our robot drive backwards and turn right in autonomous mode
Unread 24-02-2013, 16:38
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Autonomous Moving Backwards
What sensors are you using? What language?
Generally it's done by creating commands to drive or turn in X direction for a set distance (via encoder) or time, then chaining those commands together in a command group. This only applies in the text languages, I'm not sure how it works in LabVIEW
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 24-02-2013, 18:05
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
We use java for our programming
jaruar1 is our left drive motor
jaguar2 is our right drive motor
Unread 24-02-2013, 18:48
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Unless your team has used them already you should have E4P US Digital Optical Encoders from previous years' Kit of Parts. Mounting this on a drive shaft would allow you to detect the shaft's rotation to calculate the distance or speed the robot is travelling at. You can use this to tell your robot to drive a distance autonomous and then stop once it reaches that distance.
There is a gyro and an accelerometer included in the Kit of Parts. The gyro is an analog sensor that detects change in angle. Mounting this on the robot parallel to the ground allows you to tell the robot to turn until it reaches 90 degrees (right.)
If you do not use an encoder, gyro, or any other sensor to detect the robot position then the only alternative is a timer based autonomous. You can specify through logic (while statement for SimpleRobot & if then statement for IterativeRobot) to turn on the motors at specific times and turn it off when it shouldn't be running.
Example code of how a timer based autonomous could run. In the example the robot drives backwards for 1 second, sits still for 1 second, and then turn right in place for 1 second.
Timer timer = new Timer();
Jaguar leftDrive = new Jaguar(1);
Jaguar rightDrive = new Jaguar(2);
autonomousInit() {
  timer.start();
  timer.reset();
autonomousPeriodic() {
  double currentTime = timer.get() * MathUtils.pow(10, -6);
  if (currentTime < 2) { //if time is less than 2 seconds
    leftDrive.set(-0.5); //drive left motors backwards
    rightDrive.set(-0.5); //drive right motors backwards
  } else if (currentTime  >= 2 && currentTime < 3) { //time between 2&3 secs.
      leftDrive.set(0);
      rightDrive.set(0);
  } else if (currentTime >= 3 && currentTime < 4) { //time between 3&4 secs.
     leftDrive.set(0.5); //set left forward to turn right
     rightDrive.set(-0.5); //set right backward to turn right in place
Unread 24-02-2013, 19:09
F22Rapture's Avatar
AKA: Daniel A
Just out of curiosity Magi, what does MathUtils.pow(10, 6) do?
- Wernher von Braun
Unread 24-02-2013, 19:39
MagiChau's Avatar
AKA: Michael Chau
It raises the first parameter (10) to the second parameter (-6) power. So the result is 10^-6. I probably should use scientific notation instead. I am multiplying the time by this assuming the javadocs is correct that the timer returns the time in micro seconds.
Unread 24-02-2013, 19:49
Originally Posted by MagiChau View Post
It raises the first parameter (10) to the second parameter (6) power. So the result is 10^6. I probably should use scientific notation instead. I am multiplying the time by this assuming the javadocs is correct that the timer returns the time in micro seconds.
You should probably multiply it by 10-6 (if you want seconds).
Unread 24-02-2013, 19:59
MagiChau's Avatar
AKA: Michael Chau
Oops, fixed it now.
Unread 24-02-2013, 21:41
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Our team is not using encoders for the drive system only the shooter this year. I just want the robot to drive backwards when the first 3 shots are fired. That takes about 9 seconds i have it for and then it will switch to low gear. then i want it to just drive straight back for the rest of the autonomous period.
Unread 24-02-2013, 22:07
F22Rapture's Avatar
AKA: Daniel A
In that case, you would want something similar to Magi's example, since that's based on time.
You could also create a commands for driving, shooting, etc. and then string them together in a command group and have them execute in-order. That would require a bit less tuning to get right, though it might take longer to initially program.
- Wernher von Braun
Unread 25-02-2013, 10:20
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Be careful that you do not cross the center-of-the-field line
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
