Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 24-02-2013, 22:54
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Is there a speed sensor input example for Labview?
See my cad pic, Yellow indicating where the reflector tape is mounted.
90 degrees on, 90 degrees off, 90 degrees on, 90 degrees off, as it spins.
With the low resolution counter method in bang-bang, the difference between (I am going from memory from a couple of weeks ago) in a 10 ms loop, it was 9, 10, or 11 counts, which equated to 3000rpm, 3300rpm, 3600rpm. We realized that if the tape did not start at 180 degrees apart, this was an issue and an error. As we increased the loop time to get more counts, we were reducing the motor output changes which increased the error.
We are using the "gear tooth" mode, and a timer avg over two counts, which is one revolution. This really reduced the error in not placing the reflector tape exactly 180 degrees apart.
Does that make more sense?
Edit, Banner part number DS18VN6LP
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 24-02-2013 at 23:08. Reason: added banner part number. DS18VN6LP
