Go to Post Giving POWER and CHOICE to the people is the best route. - Franchesca [more]
Unread 02-25-2013, 01:55 PM
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
Re: Balancing a Pneumatic wheel
Originally Posted by FrankJ View Post
For the tire wheel weights, mounted on the inside of a wheel: They are being used exactly as the MFR intended in a less severe than typical application. In this case the supplied double sided sticky tape is tested & sold for this application. Of course they need to be properly applied to a clean surface.
How are you evaluating "less severe?" These weights are sold for auto & motorcycle tire balancing. An automotive tire will rarely see over 1000rpm. Small trailer tires may be as much as double this but no where near 3k-5k rpm. I'm surprised no one is discussing the Dynabeads mentioned in an earlier post. Much better balance solution for this application. They claim to deliver precise balance and they are contained. I have not used them but I've seen a number of credible reviews on them from the motorcycle community.
This still doesn't allow teams to use components beyond their rated capacities. Even with the best balance solution, if the wheel/tire falls apart, they are all dangerous. If the vendor description of the item has a 5000 rpm recommended limit, that should be considered the maximum safe operation condition.
Regards,
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
