Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 25-02-2013, 13:20
Team UPDATE - 2013-02-22
Didn't see anyone post about this.
Game Manual
The following field drawings have been updated to reflect current designs:
Goal Bottoms
Goal Chains
Pyramid Cap Locking Mechanism
Updated drawings can be found on the Manual Homepage
Unread 25-02-2013, 13:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Team UPDATE - 2013-02-22
Lets hope the changes actually help to keep frisbees in.
Mentor 2415
Unread 25-02-2013, 13:41
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Have people shot at goals with their chains tied together like that?
We haven't had any trouble with discs staying in the goal and our exit velocity it crazy.
It seems to me that with the ends tied together the discs would be more likely to not stay in as they would hit a wall of chain and bounce back.
2012-Present Wave Robotics Team 2826
Unread 25-02-2013, 13:46
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
This hopefully will fix that issue, the bounce back of frisbees really took away from the great scorers.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
AKA: Sean
Where are you shooting from and what height is the frisbee leaving at that you havent had problems?
Depending on where we shoot from it is either a huge issue or nonexistent. From our ideal shot it is a huge problem and at least half bounce out. From full field or from closer than our proposed shot it doesn't seem to be an issue.
Mentor 2415
Unread 25-02-2013, 13:49
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
If you are concerned that this might increase a problem with frisbees bouncing out I wonder if this is the GDCs attempt to slow down frisbees coming from robots.
Unread 25-02-2013, 13:50
We are shooting from behind the pyramid, next to it, and as you've seen from a video next to the feeder station. Maybe ours are staying in because we have(from what I can tell from other teams videos) more spin on our discs....
Unread 25-02-2013, 13:55
AKA: Sean
Spin could be the answer. Ours has a pretty absurd amount too though. is your behind the pyramid shot going above or below the first rung? Ours is below the first rung and below the second rung on the opposite side of the pyramid. This is with the shooter running at the full-court speed. If we dial it back it works much better.
Mentor 2415
Unread 25-02-2013, 13:56
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
This brings up a related question I had...
Has anyone constructed a regulation goal and measured the capacity? I imagine it's pretty high, but I think some elim matches can have 30+ frisbees in the goal at once. Certainly at some point, frisbees will be rejected more frequently than an empty goal.
Cold Fusion's 10th Season
Unread 25-02-2013, 13:58
We are shooting the same as you height wise, We can't run our shooter at full speed for up close shots, we only run about 50-60% for anything closer than half court.
Unread 25-02-2013, 14:01
AKA: Sean
Alright sounds like we're on the same page then. Maybe this change will let us crank it up a bit now.
Mentor 2415
Unread 25-02-2013, 14:06
Our exit trajectory is really flat, so if we go to fast at close shots we over shoot. We are already in the works getting our chains to be connected. We will hopefully find out tonight what, if any, changes we need to make.
Unread 25-02-2013, 17:21
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Can anyone clarify for me?
Did basically all they do is attach all the chain together at the bottom?
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 25-02-2013, 17:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I suppose I shouldn't be surprised at the lack of outrage at this game change, since it helps teams score more frisbess more easily. Despite the fact that many of the arguments against the HP change apply here. Namely, teams knew or should have know about the bounce problem, and several teams did account for this in their designs and tuning. So now the teams that were clever enough to not hurl point blank shots at warp speed have lost the advantage that their cleverness should have given them.
Yes, it's not as sweeping a change as the HP ruling, but I'm getting the vibe that any change the GDC makes to make shooting easier is going to be hailed as an great improvement to the game. As opposed to the late season game change that it actually is.
Unread 25-02-2013, 18:09
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I think the biggest difference is most people don't see this as something being taken away from them. I think that was the main reason for the reactions (including mine) of the previous game change. I doubt many people thought that by having their discs not bounce out that it would be a direct advantage over other teams (as we don't know that all the other teams didn't also figure it out).
