Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 25-02-2013, 17:36
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
How to read a pulse?
I would like to know how to read a pulse width with the digital sidecar DIO. Any one know how to do this?
Unread 25-02-2013, 17:44
Re: How to read a pulse?
Can you give a bit more detail about why you want to do this, what type of sensor you are getting the signal from, what is the range of widths you want to measure, and what is the period of the pulses ? It has a bearing on the answer.
Unread 01-03-2013, 23:56
enrique's Avatar
ok here is the code and the spec. I threw something together using timers, but I was wondering if there is a better way. This is basically using PWM.
File Type: h GP2Y0D805Z0F.h (625 Bytes, 10 views)
Unread 02-03-2013, 00:50
Try opening the "PDF" file you attached.
Unread 02-03-2013, 09:46
enrique's Avatar
Post Re: How to read a pulse?
Guess its corrupt. Here it is again.
Unread 02-03-2013, 10:25
What are you trying to use this for ?
Please give some details about what you want to accomplish.
Unread 02-03-2013, 10:32
enrique's Avatar
One application is to see if something is there. That works good with this code. But I would like to use it to see frisbees going by and knowing if they are backwards or not. There is a problem with using that code for distance. For example if I put "Wait(0.05);", then it changes my values.
Unread 02-03-2013, 10:47
Can you be just a bit more articulate? I could guess what you mean, but I'd probably guess wrong.
Unread 02-03-2013, 10:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If I'm reading that datasheet correctly (it's hard to be certain of that), then your sensor there is just a simple proximity sensor. It will only switch on when an object is in detection range, and off when it's not. There's no pulsing or anything to indicate the actual distance of the object. Atleast, I don't see any indication of that, for all that it talks about triangulation. Do you have some way of measuring the output to confirm that it's giving you a PWM signal and not just off-on?
Unread 03-03-2013, 22:15
enrique's Avatar
I'm using it as proximity now. I love the size! I have a few of these. If I print the "Get" function then i get a number that goes up and down according to distance from the sensor. However, the values change according to how long the loop takes. So if I add a "wait" to the teleop loop, the values from the sensor change because I'm taking too long to read the pulses to accurately measure the off time.
