Re: Team 3929 Scouting Sheet
This is a nice, complete, compact, sheet; I like it. Do you put the data into a computer for analysis & comparison between teams? If so, what do you use? And what did you use to generate it? It looks Excel-ish, but it's worth an ask.
For those concerned about space for hash marks -- reduce the width of some of the columns that can't possibly need a slew of tallies (like all of the auto goal columns and the pyramid goal) and use the space to add width to the 3 other teleop goals. It's not as pretty, but functionality has it's own aesthetics, right? ![]() |
And, yes, we did use Excel to make this sheet. |
What do you do to help reduce the inevitable differences in "driving level 3" between different scouters? And looking at the sheet again, I realized that I missed that you don't record any defense; how come? |
I'm of the opinion that qualitative information about each robot is more useful that this numerical data. We used to use custom Nintendo DS programs to scout, then loaded the data into an excel spreadsheet. The problem with that is that doesn't help at all during the competition, only during alliance selections. Even then, it doesn't tell you much about how the robot plays and how well it can fit with your alliance.
Our students are well aware that pick lists are based off of qualitative and quantitative data. |
I don't want a 2nd 42-point autonomous robot on my alliance if they're picking up the same extra 4 frisbees that we pick up. But I quite possibly might want to pick them anyway if they're almost as good a teleop scorer as the best one available..... Lots and lots of choices. It's pretty easy to get more data than you can usefully analyze; unfortunately we've been pretty "good" at that over the years. But every year we get better, and part of what's helped us end up with more useful information (instead of extraneous data) is figuring out how to quantify factors & get them into a spreadsheet for further analysis. |
#7
I guess I'm confused by the alliance/opponent part at the top left. This is meant to track a team's progress throughout an event, up to 12 qualification rounds, right? Why is there not a listing for the 12 different alliance/opponent groupings? Or leave out the alliance/opponent frame altogether?
#9
Emmett, Taylor is correct here. While you don't have much space left on the front, it is easy to get double sided sheets printed. If you move pit scouting to the back of the sheet, you can allow more space for alliance partners/opponents for each match. The reason to do this is to check quickly without the match schedule, which strong/weak teams the team being scouted played with/against. This allows you to figure out if results from a given match are due to strong defensive bots, floor loaders stealing discs, etc.. |
#10
I'm sure sharing the source excel file will also be appreciated. My team will see your work so far. I hope it ignites their interest in scouting.
#12
I'm really glad that this sheet was received so well by the community. As a second year team, scouting was not a priority last year, but we're hoping to make it better this year. |
#13
This was our 2012 sheet:
http://www.chiefdelphi.com/media/papers/2700 2011: http://www.chiefdelphi.com/media/papers/2589 and 2010: http://www.chiefdelphi.com/media/papers/2370 If you go through 2010 through 2012, you can see the evolution of what our scouts like. I really like the way your sheet is organized. With the values for a given qualifier in a clumn, it should be easy to pick out increasing trends. I think it also looks a lot easier to compile at a glance than the sheets we have been using. Our scouting sheets are primarily to support alliance selection and to correlate some calculated parameters we track. We have another scout doing "match scouting" which is where we specifically target partners and opponents and the behaviours they can offer. Overall, I really like your sheet and will ahve my scouts check it out. I love the 1 sheet/team pencil paper method and have found it very effective. Beware in alliance selection that you don't accidentally loose a sheet. Make sure you have a couple of team lists to cross reference. |
#14
Thanks for your source document. Naturally it has been hacked a bit. I had to do that for open office sanity. Font changes and some formatting streamlines made. Here's a page preview capture. Note the addition of space for the scouters' names. One sheet per team is the plan. I may make a workbook which has all of the CT regional teams in it. Fingers crossed that there will be enough interest among the team members to use this (or something) effectively.
