Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 25-02-2013, 20:41
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Axis VI help
So we are using the FRC example in LabView that output the distance to the goals. We plan to use the driver station computer to process the images so we put the .vi in the the computer part of the robot project. How can we access this during the matches so we can see the distances?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 25-02-2013, 23:58
Re: Axis VI help
If there is a value in the Dashboard program that you want the robot program to have access to, use the SmartDashboard functions. Write the value to a named SD variable in the Dashboard, and read that same SD variable on the robot.
Unread 26-02-2013, 08:46
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: Axis VI help
If I use this, do I need a receiving command on the dashboard side?
Unread 26-02-2013, 10:27
Re: Axis VI help
I didn't notice this before.
Don't put the vision code in the robot project. None of the robot code executes on the PC unless you're running it as a simulation. Put the vision code in the Dashboard project instead.
Unread 26-02-2013, 12:58
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: Axis VI help
That makes a ton more sense.
How would we implement it?
https://docs.google.com/file/d/0B2OM...V0akltOVU/edit
