Go to Post Learning by failure is quite common. - Gdeaver [more]
Unread 25-02-2013, 19:38
MichaelBielecki MichaelBielecki is offline
FRC #0195 (Cyber Knights)
Team Role: Electrical
MichaelBielecki is an unknown quantity at this point
Sidecar
The side car was working fine. After turning the robot off and then back on, I am having problems with the sidecar. The side car has 3 power supply leds. The 5v one is not on. I know it gets the 5v from the ribbon cable going to the module in the crio. I don't know what would be causing the sidecar not to be getting the 5v. Is there a way of fixing this. I checked the sidecar and it is all plugged in. The only things in it is a tachometer and a limit switch.
Unread 25-02-2013, 19:49
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Sidecar
The Digital Sidecar has to be wired to the Power Distribution Board for power. See http://www.usfirst.org/sites/default...icalLayout.pdf
Unread 25-02-2013, 20:02
Lemons's Avatar
Lemons Lemons is offline
AKA: Gooby
FRC #2383 (Ninjineers)
Lemons is an unknown quantity at this point
Re: Sidecar
We had a similar problem where only the 5v led wasn't showing power. It ended up just being some metal shavings in the sidecar. We just took an air compressor and blew it all out and it worked. This might not be your problem but it worked for us.
Unread 25-02-2013, 20:10
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
Re: Sidecar
We had a similar situation last year also. The sidecar just stopped working at an event. We swapped it out and everything started working again. Once we had time, we opened it up and found one of the components had exploded. It must have gotten some metal shavings inside of it and shorted it out.
My suggestion is to blow it out like mentioned earlier, and open it up to see if any components have been damaged. If you find any damage, replace it.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 25-02-2013, 20:35
Re: Sidecar
Thanks for the help. I opened it up and cleaned it. When i plugged it back in it worked like new.
Unread 25-02-2013, 22:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Sidecar
There is a very important lesson for all teams here.
Can you see what that lesson is?
Unread 25-02-2013, 22:22
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Sidecar
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 25-02-2013, 23:25
Re: Sidecar
Michael,
The 5 volt supply is derived from the 12 volt input to the sidecar. Some 5 volts leaks down the ribbon cable but not enough current is available to run the side car and the PWM outputs. However, the 6 volt supply is also derived from the same 12 volt input. You were very lucky that clearing the debris allowed the DSC to return to normal operations. The lack of the 5 volt LED indicated that the supply was in fault and the only thing saving you was the current limit designed into power supply. Thank you Eric VanWyk and Russ Beavis.
Unread 26-02-2013, 00:19
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Sidecar
Is it: Don't let the mechanical team near the electronics with a drill?
Damage from metal shavings
