Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 25-02-2013, 22:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Team 192's 2013 Gearbox
Originally Posted by Joey Milia View Post
I don't have any hard data on efficiency but it's just a three stage shifting gearbox, one of which is belts from the cims. All stages are in the 98%-99% range, add on the sealed bearings and I would expect an efficiency in the low 90s.
How are you getting such high efficiency per stage?
Mentor 2415
Unread 25-02-2013, 22:56
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
The main reductions are spur and bevel gears, which, when alined properly with accurate tooth profiles and proper lubrication are extremely efficient. Once again I have no measured data to support these estimates, they are based on subjective observations and engineering manuals (mostly engineering manuals).
