Go to Post I feel that I learned more last year than any previous year because of the challenges we faced. - paldrid [more]
Unread 02-25-2013, 11:15 PM
Re: PID problems
It doesn't sound like this is your problem, but a PID-controlled system can change its behavior drastically depending on the battery voltage. Just to make sure, are you seeing the "incorrect" results when using a freshly charged battery? Or was the system perhaps tuned with a weak battery installed?
