Go to Post remember FIRST is just an extracuricular activity in which most of the work is technichan's work...what gets you into college are good grades and a good course load...as my mom always said, "getting good grades gives you the freedom to chose to be whatever you want and go wherever you want" - abeD [more]
Thread Tools Rating: Thread Rating: 68 votes, 5.00 average. Display Modes
Unread 25-02-2013, 23:35
Re: PID vs Bang-Bang for Shooter Consistency
Originally Posted by lori558 View Post
the photoswitch didn't pick up the 1 stripe at high RPMs. So we switch and put a piece of tape that covers the gap between 1 spoke to another. So it is a thick stripe...
OK, that is what I was concerned about. That photosensor isn't exactly a speed demon. It needs a wide stripe. The wider the better (up to 180 degrees of arc, no more).
Currently it is set up according to a tachometer:
Yes, that's the "period" method (method2) that I was talking about in my previous post.
Ether:
With a low count-per-rev sensor, you want to use the 2nd method, not the first.
How exactly do I go about programming that?
If you're using this, you're already doing it.
The code thus far is attached!
The code doesn't look right to me, but I'm not a LabVIEW guru. It looks like you are converting the period to rpm, then subtracting the previous rpm value from it, then comparing it to a period. Bill or Mark, can you please jump in here and help him?
