Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 24-01-2003, 23:12
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
No reduction
If two dissimilar gears are mounted on the same shaft, then there is no reduction.
However, using this setup coupled with other gears is a good way to produce a reduction.
Here is an example:
A Fisher-Price motor has a 19 tooth gear.
This 19 tooth gear is mated with a 57 tooth gear, providing a 3:1 reduction translated to the shaft which the 57 tooth gear is mounted.
On that same shaft which the 57 tooth gear is mounted, there is another 19 tooth gear, attached to the same shaft.
Now, this second 19 tooth gear is meshed with a 4th gear, a 38 tooth gear, which provides an additional 2:1 reduction.
The total reduction of this system is a 6:1 speed reduction, done in a very small package.
Andy B.
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
