Go to Post Although it is tempting, try not to toot your own horn in this thread. While you may have an awesome bot, the real compliment should come from other teams. - Andy Baker [more]
Unread 26-02-2013, 19:13
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Getting Wheel RPM
Now that build season is complete it is time for some fine tuning of things. What I would like to do is use some sort of encoder (any suggestions would be much appreciated) and use it to consistently run our shooting wheels at a set rpm. I am fairly certain a DigitalInput object would be used to do this, however, I have no experience with either the sensor or the programming. Any suggestions or sample code would be much appreciated. Thanks in advance for the help.
Unread 26-02-2013, 19:27
Re: Getting Wheel RPM
There are literally hundreds of recent posts here on CD about this very topic. Try doing a little searching and reading, then come back here with specific questions.
Here are some search words:
shooter encoder Hall effect speed control bang-bang photosensor
