Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
Unread 26-02-2013, 15:48
Doctor Gandalf's Avatar
Doctor Gandalf Doctor Gandalf is offline
AKA: Kellan
FRC #0617 (The Enginerds)
Doctor Gandalf is an unknown quantity at this point
Question [FTC]: [FTC] Labview Servo Malfunction
Hi guys,
I'm trying to program a new arm for my FTC team (3116) to use at states. It uses three servos (one at the bottom, one in the middle, and one as a wrist), which I set up to individual buttons; each has two (up and down).
When I tested the program, it repeatedly switches up which servo goes to which button.
I tried to troubleshoot, first by replacing the NXT (three different ones with the same problem) and the servo controller (two different ones, no fix). Then, I tried to use a new program. Rather than making two case structures nestled in each other (like the auto generated code), I unpacked the controller button cluster, sending each button to an individual if else test.
This worked better, but it wouldn't store the value of the buttons (meaning the servos would constantly move between the positions) - and the NXT wouldn't let me make a Boolean memory unit to store the data. It is important to note that the servos didn't respond to the wrong signal at that point.
Is there anything I missed? It seems to be a problem in the coding, but I'm not sure what needs to be fixed. Is there a better way to program the servos than what I tried?
Thanks for the help!
Unread 26-02-2013, 17:07
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Re: [FTC]: [FTC] Labview Servo Malfunction
Can you post your code?
let tau = 2pi
Unread 26-02-2013, 21:03
AKA: Kellan
Smile Re: [FTC]: [FTC] Labview Servo Malfunction
I'd love to, but I'm not certain how to. Would you mind explaining for me? Thanks!
Unread 27-02-2013, 14:09
Probably the easiest way is to use the share button on the Robot Project Center. This will zip up your entire project which you can then upload.
Alternatively, you can select the code in question and choose "create .vi snippet from selection" from the edit menu. Details are here: http://www.ni.com/white-paper/9330/en
let tau = 2pi
