Go to Post I, for one, refused to be railroaded down this train of thought so easily! Geeze, one lousy game hint just builds up steam for any old picture to come through and go two pages in a matter of hours. - Billfred [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #76   Spotlight this post!
Unread 26-02-2013, 10:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Event Predictions
Originally Posted by AllenGregoryIV View Post
I'm still not sure this rule was as much for safety as it was for game mechanics. With out this rule 2006 would have been a very different game. Full court shooters in 2006 would have completely broken the game.
Psssh, don't tell me that seeing an endless cycle of poof balls being lobbed from opposite corners to the goals wouldn't have been stupidly entertaining. Plus there could have been all sort of "don't cross the streams" jokes.
  #77   Spotlight this post!
Unread 26-02-2013, 10:39
JohnFogarty's Avatar
Trapped under a pile of Mechanums
AKA: @doctorfogarty
Originally Posted by mwmac View Post
Would not be surprised to see First implement a shooter wheel safety check in the queue to spot unsafe wheel balancing....
See this is where I get really confused that teams don't do what we did...
It's obvious that the Innertube's air nozzle is why the wheel spins off balance.
So we took ours out and filled the tire with pool noodle foam. No more fuss whatsoever. It's probably 100x safer as well.
John Fogarty
  #78   Spotlight this post!
Unread 26-02-2013, 10:41
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Sounds like a simple and safe solution...
  #79   Spotlight this post!
Unread 26-02-2013, 13:52
Racer26 Racer26 is offline
Except for the part where pool noodle foam doesn't get you the adjustability of changing the air pressure in the tire to adjust how it grips the DISCs.
Also, maybe I'm just not envisioning it correctly, but I dont see how you prevent the tire from pancaking at speed too. I spun up an AM pneumatic 1:1 on a CIM, with no air in the tire, and the tire visibly pancakes a substantial amount.
  #80   Spotlight this post!
Unread 26-02-2013, 13:54
I thought FIRST mandated that all moving parts had to be shielded in the robot.
Only relevant rule I can find is this one:
Originally Posted by 2013 FRC Game Manual
R08
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
  #81   Spotlight this post!
Unread 26-02-2013, 21:12
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
If that is true our robot is not rule-abiding. I could not find any rule that states this....and we have our shooter wheels on top of the robot very much so exposed.
  #82   Spotlight this post!
Unread 26-02-2013, 22:33
AKA: @doctorfogarty
Our tires don't pancake at all.
Of course I can't prove this without the robot, but The foam works wonders. We adjust the compression by change how much of the tire actually contacts the Frisbee itself.
John Fogarty
  #83   Spotlight this post!
Unread 26-02-2013, 22:40
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
With air or foam in the tire, the AM will not pancake nearly as much as with no air. In our testing, we found that being able to adjust tire pressure and Frisbee compression (e.g. moving the wheel in and out) was beneficial. For that reason, we decided not to use foam.
Our shooter is mostly encased in 3/8" aluminum and the only exposed part of the wheel is covered by Lexan. So if it decides to grenade, the blast should be contained.
  #84   Spotlight this post!
Unread 27-02-2013, 00:50
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I used to be a FIRST Robotics mentor...then I took a Frisbee to the knee.
  #85   Spotlight this post!
Unread 27-02-2013, 00:56
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
You sir have made my season!
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
  #86   Spotlight this post!
Unread 27-02-2013, 02:51
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
That should be a button.
  #87   Spotlight this post!
Unread 27-02-2013, 02:53
DampRobot's Avatar
Physics Major
AKA: Roger Romani
This is so much better than all those stupid "do you even lift (for 30)" memes!
-Plutarch
  #88   Spotlight this post!
Unread 27-02-2013, 11:53
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Based on the safety concerns i'm wearing my masks (I have 2 of these)
