Go to Post I am really glad that FIRST gives teams the choice to use either students or adults in this role. - dtengineering [more]
Unread 26-02-2013, 23:25
wre136's Avatar
wre136 wre136 is offline
AKA: Will Edds
FRC #2461 (The METAL-SKINS)
wre136 is an unknown quantity at this point
Possible Wrong Wiring in FRC Vision Tracking Example
In the "Rectangular Tracking - 2013.lvproj", there is the "distance.vi". I believe either something is wired incorrectly there or this post is incorrect on which camera axis resolution you should use.
As from the post, it states that if you are trying to compute distance based off of the height of the sides of the rectangle, then you should use the Y axis resolution which is 240.
However, in the distance.vi (Attached to this post), it is obviously using the X Axis resolution of 320. The code still looks like its comparing against the height of the rectangles so this causes me some confusion.
Is the post wrong, the code wrong or am I just reading this wrong?
Name:	Bad FRC Programming.PNG
