Thread Tools |
Rating:
Display Modes |
#8
Re: Which Legal Compressor has the most power?
This is a repost, but it applies to the topic:
Here's a test that was run on the same system/same fully charged battery/different compressors. System held pressure for 5 minutes after test. Thomas 405ADC36/12 (from 2009 kit) VIAir 90 (purchased through AndyMark) Ambient temp: 68 degrees Humidity: 50% Altitude: 65ft above sea level Volume (including hoses/tanks): 360 cubic inches Battery voltage at start was 13.6v. During compression the voltage was ~12.4v (+/- .1v). At the end voltage was 13.02 for both. -----------Thomas --------- VIAir Time --- psi/temp ------ psi/temp 0 min ----- 0/68d ---------- 0/68d 1 min ---- 60/70d --------- 30/69d 2 min ---- 85/71d --------- 60/72d 3 min --- 110/74d --------- 80/73d 3:31 ---- 118/74d (cutoff) 4 min ----------------------- 100/83d 4:31 ------------------------ 118/85d (cutoff) __________________ |
