Go to Post ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... :( . - dlavery [more]
Unread 27-02-2013, 14:01
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Power Distibution Board - Broken stud
The PD shanks are fragile, when compared against steel M6 screws. The PDB doc (here) states, on p.7, that the shanks can shear if torqued to more that 3.9 N-m. That's about four pounds of force at the far end of an eight inch wrench. Not nearly as much torque as is typically recommended for steel M6 screws -- about 10 N-m for Class 8.8 or 15 N-m for Class 10.9.
However, the OP clearly stated that the person with the wrench was a veteran electrical mentor guy. I agree this one is probably just bad luck. One of the best students on our team had similar bad luck a couple of years ago.
Richard Wallace
since 2003
