Go to Post If all you are is a nail, every hammer looks like a problem. - Alan Anderson [more]
Unread 27-02-2013, 16:03
lonski lonski is offline
FRC #2486
lonski is an unknown quantity at this point
Exclamation Cypress Programming Help
Hello,
We are trying to use the Cypress I/O Board this year but have ran into some issues trying to program it with the hex file. We are following the directions on the Control Systems manual that first provides and are using the software that was installed with the driverstation. The message that we get when we try to program FRC_IO.2012.v3.hex is "The hex file does not match with the acquired device, please check the device." I have gone through the troublshooting that FIRST provides but everything is correct there. Does anyone know how to fix this issue because I am out of ideas so far. Thanks
Unread 27-02-2013, 16:17
FRC #2486
Re: Cypress Programming Help
I did look into some other files and I need the older 2010 firmware for our board. Does anyone know where i can find the older 2010 firmware for the cypress board from the 2010 kit's?
Thanks
Unread 27-02-2013, 17:35
Check this thread, paying special attention to posts #2 and #8.
