Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 25-01-2003, 05:35
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally posted by Lloyd Burns
The big problem with the gyro, if it is used for dead reckoning, is that it goes non-linear at turn rates less than 90 degrees/second. This is the turn rate of your forearm as you raise it from horizontal to vertical over a whole second ("one steamboat"). If your robot turns only that fast, it will appear quite sedate. If it turns faster, your robot can't tell where it is heading.
It's actually worse than that.
The GyroChip which we got in the kit, for a few seasons, until 2003, actually had a maximum detectable rate of 64deg/sec, after which it's maxed out. This year's GyroChip is only marginally better at 75deg/sec.
Basically, if you're planning on having a quick drivetrain, and using it to its full potential, you're not going to be able to use the GyroChip to dictate your rate of turn, without some tweaking.
references:
http://www.systron.com/prodinfo/AQRSSpc.html
http://www.systron.com/GyroChip%20Theory.pdf (page 5)
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Usage of the gyro jon virgi General Forum 37 09-06-2003 11:57
gyro code odin892 Programming 2 08-04-2003 14:50
gyro odin892 Programming 0 08-04-2003 09:59
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
