Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 26-02-2013, 21:32
eruiz22 eruiz22 is offline
FRC #4210
eruiz22 is on a distinguished road
Question My autonomous code isn't working.
I want the "Motor for actuator" to go down for 10 seconds. Then the "Swing" to go foward for 5 seconds. Finally, the "Motor for actuator" to go up for 15 seconds.
I built and deloyed the code. When I pressed button 11 on joystick 2, nothing happened. Is my code correct?
Thank you.
ID:	14198  Click image for larger version
Unread 26-02-2013, 22:04
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: My autonomous code isn't working.
The first issue I see is, joysticks are not read in Autonomous mode. By placing your code in a case structure that is dependent on that input, you are preventing it from running.
Unread 26-02-2013, 22:15
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
I thought the initial value was read when autonomous started, but it couldn't be changed during autonomous. As it stands here the false case should be running. If the button was being pressed as autonomous started it would run the true case. Since you can't touch the control as autonomous starts you'd have to tape a rock to the button or something if you wanted the true case to run.
Below is a quote from a comment within the autonomous default project.
Note that all Driver Station inputs are automatically latched and will not change once auto begins.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 26-02-2013, 22:39
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
The code in the second picture is not needed, and the case structure and the vi's connected to it should be removed. All you need for autonomous is the while loops.
Unread 27-02-2013, 00:11
billbo911's Avatar
You are correct. Although, I believe the OP was stating that the button was pressed after Autonomous was started.
Unread 27-02-2013, 21:32
FRC #4210
I removed the joystick, left the case structure, and enclosed everything in a while loop.
I'm sure that this is the wrong way to go about this.
Can you please explain how to fix this code in simple terms?
Thank you!
Unread 27-02-2013, 21:36
FRC #4210
So then remove the case structure and add a while loop?
Why is a case structure inappropraite for my objective?
Unread 27-02-2013, 22:54
FRC #1972
The code within the case structure is correct. The case structure is inappropriate for autonomous because it requires you to manual change the value. Sorry, i mixed up my structures, you were correcting having the sequence loop, while loops are for autonomous also, but i have no experience with them. Keep your sequence, and remove the case structures.
Unread 27-02-2013, 23:49
FRC #4210
Makes sense.
Thank you for clearing that up
