Go to Post That tetra has personality! - Kevin Thorp [more]
Unread 25-01-2003, 07:35
Walter_Jr Walter_Jr is offline
Walter_Jr is an unknown quantity at this point
Send a message via AIM to Walter_Jr Send a message via Yahoo to Walter_Jr
What do you think of team 61 robot
Give some feedback on what you think of team 61 robot for this year.. If you have any questions i will be greatly glade to answer them.. Although i can't tell you everything i can tell you some stuff about it.. We have our own secrets two you know!!!!
Unread 25-01-2003, 07:37
o ya our robot you can find it in the gallery or click on the link below
http://www.chiefdelphi.com/forums/pi...DESC&sort=date
Unread 25-01-2003, 08:25
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
it looks pretty coolio..heh i like the drive train, but i cant really figure out what those bars are gunna be for unless you still need to add some kind of grabber thing on the end of it, but anyways it looks cool, compared to all we have is drawings on CAD at the moment...
Unread 25-01-2003, 08:37
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
Ok...
So what's it do?
---Lightning Robotics!---
Unread 25-01-2003, 08:41
Its designed for plowing through the boxes and being the KING OF THE HILL.... The arms are used for blocking and for moving boxes so we can hold on to them some what.. when the arms are extended through the front or rear they are 5' apart and from either side they are 7' 2".. They are made out of steel.....
Unread 25-01-2003, 09:05
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
well, since you have the old bosch and old chippy on that bot, it looks like you still have a lot of work converting your old 2002 bot
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 25-01-2003, 09:11
thats our robot right there we just have to put the motors on the arms and we are done......
Unread 25-01-2003, 09:15
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Good Strategy...but....
What are you going to do if the boxes aren't there when you get there?
Have you got good backup strategy in case plan A can't be achieved?
Unread 25-01-2003, 09:17
Yes we do but its still kind of being worked out...
Unread 25-01-2003, 13:59
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
did some one say we are converting our old robot for this years competition?
Yeah some one did, but i hate to break it to you, its a brand new robot, brand new everything (well almost) Thanks tho
Unread 25-01-2003, 14:28
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
What's not brand new?
Unread 26-01-2003, 09:25
Paper Eater
if i told you i would have to kill you... =)
Unread 26-01-2003, 09:38
Yes we would...........................
Unread 26-01-2003, 09:46
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Isn't that the same base as last year?? As in drive train, and body and everything inside?
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 26-01-2003, 10:05
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
http://www.valleytech.k12.ma.us/Robo...2%20Gears1.jpg
Last years drivetrain: Note the smaller drill last year.
http://www.valleytech.k12.ma.us/Robo...op%20View2.jpg
Last year body: note the nice paint job, note the steel in the front, note the back of the robot solid wood.
Look for the drill holes from last year if you think this is last year base.
Look at 2 year ago base: This look more like this years robot.
http://www.valleytech.k12.ma.us/Robo...Bridge2001.jpg
Look at 3 years ago robot:
http://www.valleytech.k12.ma.us/Robo...s/roboti73.jpg
Do you see a pattern. We stay with something that works. We build a new base every year. We make changes as we go like this year we build strong rail system for the tracks. Different tracks this year, it is hard to tell but yes they are different. Look at the motors they are new because of the new drills we got. So if you think in any way we do not follow the rules you would be wrong. We like to be able to put our robot together quickly.
Why change the design every year. This way we can spend more time on the task at hand.
Nothing says we can't use the same design we just can't use anything from the last year parts unless noted in the rules.
Take at look at our web site and you will see all the different robots each year. We don't have picture on the web from our 1994 robot but you would see the same style as we have now the only different is it was 36" wide instead of 30".
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
