Go to Post The game is leaking? That can only mean... - GeeTwo [more]
Unread 28-02-2013, 17:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Magnetic Sensor
Inf would be because you're getting 0 for the period. Try setting the MaxPeriod to something reasonable. gts.SetMaxPeriod(0.25) or so. The counter class clears out the buffer if it doesn't see a pulse in within MaxPeriod seconds, and I don't know what the default is. Past that, I made my own class that did a little filtering of values so I'd ignore values I knew were bad. I've attached the files, you can try using it. You'd just need to modify "prevResult = 60.0 / period;" to read "prevResult = 10.0 / period;" And you'd want to reduce periodThreshold in the .h file to something like 1e-3 just so it doesn't limit the max RPM to something less that what you can actually output. It's set up so you can use it as a PIDSource for a PIDController.
Unread 28-02-2013, 17:58
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Magnetic Sensor
i changed :
m_counter->writeTimerConfig_AverageSize(6, &localStatus);
to:
m_counter->writeTimerConfig_AverageSize(1, &localStatus);
and im getting a consistant rpm with that function i had in there. every once and a while ill get a blip of 30k rpm or something should the set max period fix that?
Edit: consistent rpm of 247 rpm when i do
talon.Set(.1);
Unread 28-02-2013, 18:10
Re: Magnetic Sensor
Does it looks like your wheel is turning at 247 RPM? That's about 4 revs per second. Max period wouldn't help with the 30k blip. That's why I added a minimum period check in my RPMCounter class to ignore any period values that were obviously too small. Max period will help if your feedback is going from some number like 100 straight to zero. or flashing between 0 and 100. That's the counter thinking the wheel hast stopped and sending a 0 for period, then sending a good value when it sees the next pulse. Less likely to happen on your setup since you have 6 screw heads.
The 30k problem might be your screwheads. The GTS might be picking up the small gap in the screwhead for the flathead screwdriver. Using a hex-head fastener or something without the gap in the middle would probably work better.
Unread 28-02-2013, 18:14
Re: Magnetic Sensor
ok sweet the only problem im having now is the random blips of high rmp you said that in your rpm counter class you used a function to ignore small rpm can i do that to ignore the high ones as well?
Unread 28-02-2013, 18:20
Re: Magnetic Sensor
Take a look at the RPMCounter class I uploaded. In the GetRPM function I'm comparing the period with a constant value I set in the .h file. The idea is that if the period is less than some value, you ignore it and return the previous value.
Unread 28-02-2013, 18:30
Re: Magnetic Sensor
Ahhh thank you for your help. Two more quick question why would i need to change the "periodThreshold in the .h file to something like 1e-3". Also in the .cpp you have
for the proper calculation of the rpm shouldnt it be something like:
 prevResult = ( ((1 / period) / 6) * 60)
or at least thats the function im using to calculate the rpm
