Go to Post Hey Baker - get a haircut! :) - Sean Schuff [more]
Unread 28-02-2013, 17:27
jwhite jwhite is offline
FRC #2823
jwhite is an unknown quantity at this point
PIDController (.cpp) issues and concerns
I thought I'd report some troubles we found with the pid controller code while we're waiting for our regional.
We wanted to use the PIDController class to control a Jaguar for rate control. (And yes, if we'd done CAN protocol, we wouldn't need this, but we're not that cool a team...yet).
But it seems to me that the current code really does not work well for rate control.
The Screen Steps Live documentation for using the PIDController to govern a rate:
http://wpilib.screenstepslive.com/s/...rs-pid-control
seems to suggest that the 'feed forward' term will help. But kF is just a constant offset. We were not able to get any kind of PID tuning that was workable just using that.
We ended up wrapping the Jaguar class with another class that implemented PIDWrite as a delta, not an absolute, and that gave us reasonable results, and also seemed to be a more theoretically correct implementation. (My PID experts insist that the goal of PID code should be to drive error to 0, not to have an I term that provides a perpetual error correction).
Also, the OnTarget() method consistently crashed for us; my guess is that the use of GetError(), and the doubled critical sections cause that crash.
Hope this helps someone else.
Cheers,
Jeremy
Unread 28-02-2013, 18:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: PIDController (.cpp) issues and concerns
We're using a very slightly modified version of the PIDController class quite successfully for speed control on 3 shooter wheels. The only modification is to change the integral anti-windup measures to work slightly differently. We're using P, I, and FF terms and it's working well. A velocity PID like you're using is technically more correct, but whatever works.
What kind of crashes were you getting with the OnTarget method? We're using that to determine when to exit the shooter speed setting command, so it's getting called every teleop loop, and we haven't had any problems.
Unread 28-02-2013, 18:10
Are you running the 2nd C++ update from 2/7? It has a fix for OnTarget hanging.
Unread 28-02-2013, 18:39
FRC #2823
My recollection is that we still had an issue after that update. Sadly, we're not in a good position to retest (darn bags :-/).
Unread 28-02-2013, 23:49
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
It's still quite simple just to make your own OnTarget() method as well as GetError(). Even though it is more redundant, it should not lock the thread like it will otherwise. Simply, use GetSetpoint() and PIDGet() from your PIDSource object to calculate the error. From there, you can tune your OnTarget() error. For example...
//PIDSource is called source, PIDController is called controller.
float error = controller->GetSetpoint() - source->PIDGet();
float tolerance = error * .05; //any percentage value
return fabs(tolerance) < 5; // a tuned value
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 28-02-2013, 23:50
FRC #2823
Oh, sure, and that's what we did. I was just mentioning the troubles we had in case any listening WPILib authors were interested in fixing 'em...
Unread 28-02-2013, 23:53
Tanaythan's Avatar
Programmer
AKA: Tanay Nathan
If I recall correctly, it was noted to the WPILib authors and in one of their logs in wpilib.screenstepslive.com, they had mentioned they fixed this problem. You can just resubmit a ticket to them at this link.
Tanay Nathan
Programmer
Unread 01-03-2013, 10:08
FRC #2823
Yeah, good point, that's where I should add a note after we retest. I find the firstforge web site a bit deceptive; it has good activity, but then bits of cruft. What's nice about posting here is that you get immediate answers
Cheers,
Jeremy
Unread 02-03-2013, 01:54
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Our team also had issues with the WPILib PID implementation, and we ended up doing pretty much the same thing: wrapping the Talon class to use PID output as a delta rather than an absolute. So far it's been working alright, but it's ugly.
