Go to Post To be blunt: how many motorized carts do you see parked on the side of Einstein? - Koko Ed [more]
Unread 12-01-2013, 20:58
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Frc 2013 driver station problem
My team just finished updating all the software US FIRST specified. We followed the order of instillation that FIRST recommended. When we attempt to run the driver station it says that it needs the 2012 lab view for the driver station to run. Has this happened to anybody else, and how did you fix it?
Unread 12-01-2013, 21:15
Re: Frc 2013 driver station problem
Did you install the FRC Tools as specified in http://wpilib.screenstepslive.com/s/...-for-c-or-java
Unread 12-01-2013, 21:18
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
We tried updating our old classmate but realized that we had to get the entire image off of the usfirst website. As for our normal driver station which is a dell laptop, running the utilities update, driverstation update and labview update worked perfectly fine for us...
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 12-01-2013, 21:29
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
If it is the same error that I have seen, then it should link you to a page where you can download the 2012 LabVIEW runtime. Make sure you use the 32bit version.
Unread 13-01-2013, 11:03
FRC #3200
I am pretty sure we didn't get the NI DVD we downloaded the exe files from the FIRST website.
Unread 13-01-2013, 12:58
The LabVIEW DVD should have been in the black Kit of Parts tote. Ask around to see if anyone on your team knows where it is. The window for reporting missing KOP items has closed, so you wouldn't be able to request a replacement through normal channels.
Unread 14-01-2013, 15:01
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
Install the NI Lab View Package. Also if you have a previous years driver station on that laptop lets say 2011 or 2012 for example you need to uninstall or you would need to place those under a new directory in you :C drive. such as driverstation2012 and then let the new driver station create its own directory.
hope this helps
also you could try installing the whole package lab view, utilities, driver station.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 19-01-2013, 20:09
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We ran into the same problem. Is this the right runtime to put on the classmate?
http://joule.ni.com/nidu/cds/view/p/id/3433/lang/en
That will be easier than trying to find a USB CD drive to load it from the labview disk.
As for downloading the image for the driver station, the First website currently has this: (but it has a line striked though it)
Update: The Intel site hosting the Classmate Image is currently down. We are working with Intel to fix this problem. Thank you for your patience!
Brian K
Team 1225 Robotics Mentor
Unread 19-01-2013, 21:12
If you have an older E09 Classmate (2010 KOP), then it's difficult to install more than the Driver Station support without using the special Classmate images FIRST provides. The special Classmate images are again available for the site linked to on the FIRST KOP site.
If you have a newer E11 or E12 Classmate, then you should use the special FRC LabVIEW DVD (or the appropriate classmate image).
You don't need an external USB DVD drive to use the KOP LabVIEW DVD.
Just copy the contents of the DVD onto a USB stick and install from the stick onto the Classmate.
Unread 21-01-2013, 11:53
fizxtchr fizxtchr is offline
Cass Tech Nerd Master
AKA: Karl Balke
FRC #2673 (Tenacious Technicians)
fizxtchr is an unknown quantity at this point
FRC Dashboard will not load in Driver Station on an E09 Classmate.
We have the E09 Classmate and are attempting to only use it as a driver station. I have reimaged the Classmate with the Driver Station image from the instructions, installed the LabView Updates, Utilities Update, Driver Station Update (in proper order).
The FRC Dashboard and Driver Station both initially loaded, but now only the Driver Station will load in User/Driver Station.
Both programs will load in User/Developer, but with the title bars.
I tried reinstalling the updates, to no avail.
Do I also need to install the LabView Image? The poor little E09 only has 892 MB free now.
Can I move the Driver Station and FRC Dashboard programs to the STARTUP menu on Developer and use it (User/Developer) as the Driver Station? Efforts so far have been futile.
Time to retire the E09 Classmate?
Unread 21-01-2013, 12:02
Our E09 works fine as a Driver Station.
You just need a little investigation.
You can choose to run the Driver Station/Dashboard under the Developer account instead. Just hide the task bar and use the Window Mode button on the Operation tab to anchor the windows and it'll look just like the Driver account is supposed to.
There are a couple of reasons that the Driver Station might not be able to start the Dashboard automatically for you.
Look on the Setup tab and make sure the Local Dashboard is selected and the Default Dashboard Type is selected.
You can look in the Driver Station initialization file to see what settings are messed up, too.
Look for the Dashboard settings in:
C:\\Users\Public\Public Documents\FRC\FRC DS Data Storage.ini
Out-of-the-box you should see these:
DashboardLocal = TRUE
DashboardCmdLine = ""C:\\Program Files\\FRC Dashboard\\Dashboard.exe""
DashboardType = 0
Unread 21-01-2013, 12:03
Domtech's Avatar
I Do Everything
AKA: Dominic
I believe that IS the one I have used to fix that problem.
Unread 23-01-2013, 22:22
SuperBK's Avatar
AKA: BrianK
Putting on the Labview runtime from http://joule.ni.com/nidu/cds/view/p/id/3433/lang/en fixed it for us.
Brian K
Unread 28-02-2013, 19:52
yeswaydude yeswaydude is offline
FRC #0304
yeswaydude is on a distinguished road
Help! We go to competition tomorrow and waited until tonight to update the classmate.
Unfortunately, I got the problem you're all describing here, and I'm stuck in the driver account with nothing but a lovely Windows background to look at.
My machine does not automatically connect to the school network, so I can't even use the web browser to download the run-time system.
Any suggestions?
I guess when I get home tonight, I might try creating a bootable USB so I can try to get access to the harddrive and disable whatever makes it automatically logon to the driver account.
Any other ideas? Are there any tricks to logging off the driver account when you don't have a driver station running?
Thanks in advance for any/all assistance!
Dave Park
Team 304 Programming Mentor
Unread 28-02-2013, 20:11
SuperBK's Avatar
AKA: BrianK
Sorry to not answer your question. Does control-alt-delete not bring up a window where you can log off?
First, don't panic. If it comes down to it, you can probably rely on somebody at the competion to have an image you can put on. (first support, other teams, etc), but I'm sure you want to take care of it yourself if possible. I would download and install the image again. Just use the basic driver station version without labview or windriver.
The procedure:
http://wpilib.screenstepslive.com/s/3120/m/8559/l/92211-imaging-your-classmate-veteran-rookie-image-download
The files
Brian
Brian K
