Go to Post "We just fundraised $5000 for registration, and you spent it all on balloons?" - [more]
Unread 28-02-2013, 23:49
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Re: PIDController (.cpp) issues and concerns
It's still quite simple just to make your own OnTarget() method as well as GetError(). Even though it is more redundant, it should not lock the thread like it will otherwise. Simply, use GetSetpoint() and PIDGet() from your PIDSource object to calculate the error. From there, you can tune your OnTarget() error. For example...
//PIDSource is called source, PIDController is called controller.
float error = controller->GetSetpoint() - source->PIDGet();
float tolerance = error * .05; //any percentage value
return fabs(tolerance) < 5; // a tuned value
Tanay Nathan
Programmer
Team #3256 Warriorborgs
