Go to Post Let's see. There's the Dean of Students, the Dean of Admissions, The Dean of Engineering, and the Dean of Kamen? Sometimes known as the Denim Dean. - Bill_B [more]
Unread 28-02-2013, 23:50
jwhite jwhite is offline
FRC #2823
jwhite is an unknown quantity at this point
Re: PIDController (.cpp) issues and concerns
Originally Posted by rawrxp View Post
It's still quite simple just to make your own OnTarget() method as well as GetError(). Even though it is more redundant, it should not lock the thread like it will otherwise. Simply, use GetSetpoint() and PIDGet() from your PIDSource object to calculate the error. From there, you can tune your OnTarget() error. For example...
//PIDSource is called source, PIDController is called controller.
float error = controller->GetSetpoint() - source->PIDGet();
float tolerance = error * .05; //any percentage value
return fabs(tolerance) < 5; // a tuned value
Oh, sure, and that's what we did. I was just mentioning the troubles we had in case any listening WPILib authors were interested in fixing 'em...
