Go to Post Weird. On a forum where people talk about robots, we have a robot trying to talk to people. - dellagd [more]
Unread 28-02-2013, 16:12
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Cool Axis 206 Camera issues.
My teams Axis 206 camera is set up how it should be, or at least how the manual said it should be, but we're not getting anything on the dashboard. What do we do?
EDIT:
Student on my account
Unread 28-02-2013, 16:26
Re: Axis 206 Camera issues.
Do you get a picture when you connect directly to the camera using a web browser?
Unread 28-02-2013, 16:29
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Did you use the camera setup tool, and do you have it properly hooked up to your robot?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 28-02-2013, 16:48
AKA: Brandon Liatys
Yes, when wired directly into the computer. Not through the CRIO.
And yes we used the tool and it configued fine. (Hooked up through the CRIO not the wireless bridge)
Unread 28-02-2013, 16:50
AKA: Spencer Lanman
Why not the bridge?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 28-02-2013, 17:43
AKA: Brandon Liatys
Originally Posted by Team3266Spencer View Post
Why not the bridge?
Because our 4 slot crio+bridge is currently bagged
EDIT: To add to that, it takes 5 hours to get a sucessful deployment of our code and when it does we open our driver station and it instantly loses connection. Were wired in with an Ethernet cord
EDIT AGAIN: Updated some stuff, seems that the crio issues are gone but still no camera
Unread 28-02-2013, 20:35
This won't work without modifying the Dashboard. The configuration expected by the default dashboard is the camera connected to the radio.
You should be able to reset the camera, set it up to work with the radio, then open the DS and Dashboard (provided the DS is set to configure your wired NIC) and see the image in the Dashboard.
Unread 28-02-2013, 23:05
It won't work even then. There's nothing running on your cRIO that will let a device plugged into one cRIO port communicate with a device plugged into the other one.
You'll have to put the D-Link (or some other router or switch) in the mix in order to connect all three devices together: the Axis camera, the cRIO, and the computer running the Driver Station and Dashboard programs.
Unread 28-02-2013, 23:21
AKA: Brandon Liatys
We managed to ghetto rig our last years bridge to work and everythings good now, but I have to ask, why?
Last year we ran it off our 8 slot crio with no problem, with the camera in the crio instead of the bridge. What changed this year? Or are you just saying between the computer and the crio the bridge is needed anyway?
Unread 01-03-2013, 00:03
When there was just the single-port WGA, a special piece of software had to run on the cRIO to forward the camera image to the Dashboard. The problem is that the single-port 4-slot cRIO can't be connected that way. Every robot now has an onboard router, so it makes sense to take advantage of it and let the Dashboard program talk to the camera directly. It's easier to support just one configuration, and it's more efficient anyway.
Unread 01-03-2013, 01:52
AKA: Brandon Liatys
Is there a reason the camera setup tool has an option for running it off the cRIO then? Because thats pretty darn misleading and would have saved some headscratching
Unread 01-03-2013, 02:47
Probably because the cRIO can still talk to the camera like that and all the code to make that work on both the cRIO and the Dashboard is still on the palettes, just no longer the default.
Unread 05-03-2013, 07:19
Since the eight-slot cRIOs can be used in that configuration, the option to setup the camera that is connected to the cRIO wasn't fully removed. I do believe the instructions encourage you to do it through the bridge, though.
Greg McKaskle
Unread 05-03-2013, 08:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
My recollections from the 8 slot crio days. When using the second port on the 8 slot crio, the camera was left with its default IP. The second port on the Crio was on the same subnet (different from the control side 10.xx.xx.2) The dashboard got its camera feed from the crio. So the widget in the dashboard is pointed to the Crios IP. With the camera on the bridge, its IP has to be in the same subnet as everything else. You had to change the camera's IP address in the dashboard widget for it to work. Now days it is default for the current setup. For it to work with the stock dashboard widget its IP address needs to be 10.xx.xx.11. If you go in & edit the widget, you can change the IP & make the camera IP whatever. Go look in the code for the older drive station & you can find the code that pulls the camera image from the Crio. Code on the crio also has to be looking at correct IP address for the camera.
If you are running the 4 slot crio on your competition bot, you really should be using the camera in the same way in your prototyping. A cheap office grade router will work for prototyping & shop testing. Even a $10 switch if you are going wired.
