Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 01-03-2013, 11:53
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Re: Air Cylinder
Originally Posted by Kevin Sevcik View Post
Art,
I've seen 5/2 valves out there in FRC. That's actually the style that Vex sells. A 5/2 valve is always sending pressure to one of the output ports. You'll need to plug one of the outputs in that case, or you'll end up dumping pressure to atmosphere when you're exhausting the cylinder. You need either a double solenoid 5/3 center exhaust valve or a single solenoid 3/2 valve.
Okay Thanks, Also so is it okay to use these Cylinders: http://www.amazon.com/SMC-NCMB075-04...matic+cylinder
