Go to Post Honesty and integrity should always be taken seriously. It's the lubrication that makes the world go round. - rsisk [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 28-02-2013, 22:56
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Air Cylinder
Is it Okay to use This kind of Air Cylinder
Unread 28-02-2013, 22:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Air Cylinder
No. R76 requires a minimum rating of 125 lb/in2.
(That general style of air cylinder appears to be allowable.)
Unread 28-02-2013, 23:11
AKA: Reginald
Re: Air Cylinder
Are Any of These Okay To use.
http://www.amazon.com/SMC-NCMB125-06...s=air+cylinder
Unread 28-02-2013, 23:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Air Cylinder
Weird. There's an exception for solenoid valves rated under 125psi, but not for cylinders. Anyways, Tristan's correct, that's illegal as it's only rated for 100psi.
Unread 28-02-2013, 23:24
AKA: Reginald
Re: Air Cylinder
This Is not the Actual Cylinder But I was wondering About The Style. I don't really Know about This Style. Its Has One Air Input Hole and i didn't know if it was okay to use.
(Note: The Maximum Working Pressure is 247 , On our Cylinder )
Unread 28-02-2013, 23:25
Re: Air Cylinder
Single ported spring return cylinder that's rated over 125psi? Sounds like an air cylinder that's rated over 125psi to me.
Unread 28-02-2013, 23:26
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Air Cylinder
There is nothing in the rules that prohibits the use of single-acting pneumatic cylinders.
Art Dutra IV
世上无难事,只怕有心人.
EricH EricH is online now
Re: Air Cylinder
For future reference, that's a spring return cylinder. Air goes in, the spring compresses, the piston moves. Remove the air pressure, the spring shoots the cylinder back to its home position.
As for whether it's OK to use per the rules, I can't find anything prohibiting any type of cylinder (see R78-H) as long as it's appropriately pressure-rated and unmodified.
Unread 28-02-2013, 23:52
AKA: Reginald
Re: Air Cylinder
Thanks For The Help, Also Do anybody know were i kind find out how to connect the single-acting pneumatic cylinders to the Single Solenoid
(Note: This Are the kind of Cylinders We are using http://www.amazon.com/SMC-NCMB075-02...s=air+cylinder
Unread 01-03-2013, 00:48
artdutra04's Avatar
Re: Air Cylinder
To use a single-acting with the solenoids usually seen in FRC, just plug the tubing into one of the two outputs of the solenoid and put a plug into the other output.
Art Dutra IV
世上无难事,只怕有心人.
Unread 01-03-2013, 09:06
AKA: Reginald
Re: Air Cylinder
How Can i Plug it.
Unread 01-03-2013, 09:46
artdutra04's Avatar
Re: Air Cylinder
How Can i Plug it.
With one of these if your solenoid has threaded connectors or one of these if the solenoid has built-in push-to-connect fittings.
Art Dutra IV
世上无难事,只怕有心人.
Unread 01-03-2013, 11:00
Re: Air Cylinder
Art,
I've seen 5/2 valves out there in FRC. That's actually the style that Vex sells. A 5/2 valve is always sending pressure to one of the output ports. You'll need to plug one of the outputs in that case, or you'll end up dumping pressure to atmosphere when you're exhausting the cylinder. You need either a double solenoid 5/3 center exhaust valve or a single solenoid 3/2 valve.
Unread 01-03-2013, 11:53
AKA: Reginald
Re: Air Cylinder
Art,
Okay Thanks, Also so is it okay to use these Cylinders: http://www.amazon.com/SMC-NCMB075-04...matic+cylinder
Unread 01-03-2013, 12:05
Re: Air Cylinder
You should be able to answer that from what we've covered in this thread, so why don't you tell me what you think the answer is and why, and then I'll tell you if you're correct. Teach a man to fish and all that.
