Go to Post Striving to build the "best robot" is a fine goal -- don't hate on it. - JVN [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 01-03-2013, 12:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Air Cylinder
Originally Posted by Reggie335 View Post
What i have Learn the Minimum Working Pressure Is 124psi. i our cylinder Max pressure is 250psi and the rule don't have any restriction on what type of air Cylinder we use so. I say We Can Use These Air Cylinders
Correct! Well. The max working pressure of the cylinder has to be 125psi, but 124psi is close enough, heh. Go forth and select air cylinders with confidence, as you now know all you need to determine if they're legal or not.
