Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 01-03-2013, 12:18
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Re: Air Cylinder
Originally Posted by Kevin Sevcik View Post
You should be able to answer that from what we've covered in this thread, so why don't you tell me what you think the answer is and why, and then I'll tell you if you're correct. Teach a man to fish and all that.
What i have Learn the Minimum Working Pressure Is 124psi. i our cylinder Max pressure is 250psi and the rule don't have any restriction on what type of air Cylinder we use so. I say We Can Use These Air Cylinders
Unread 01-03-2013, 12:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Air Cylinder
Correct! Well. The max working pressure of the cylinder has to be 125psi, but 124psi is close enough, heh. Go forth and select air cylinders with confidence, as you now know all you need to determine if they're legal or not.
Unread 01-03-2013, 12:35
AKA: Reginald
Re: Air Cylinder
Thank You Very Much For The Help
Unread 01-03-2013, 13:04
Racer26 Racer26 is offline
Re: Air Cylinder
Art,
I've seen 5/2 valves out there in FRC. That's actually the style that Vex sells. A 5/2 valve is always sending pressure to one of the output ports. You'll need to plug one of the outputs in that case, or you'll end up dumping pressure to atmosphere when you're exhausting the cylinder. You need either a double solenoid 5/3 center exhaust valve or a single solenoid 3/2 valve.
Not sure why you think that you couldn't run a spring return cylinder on a 5/2 valve.
5/2 single solenoid valves typically used in FRC have 3 ports on the input side (EA, P, and EB), and 2 ports on the output side (A, and B). When the solenoid is not energized, P->A and B->EB. When the solenoid IS energized, P->B and A->EA. If I connect my spring return cylinder's port to B, and plug A (either with a brass plug, or a hose to a T that has a loop of hose between its other two legs), this will work perfectly.
Truly, I have even built a pneumatic system on an FRC bot that could stop in the middle of its travel by using a second valve to control whether or not EA/EB goes to atmosphere.
Unread 01-03-2013, 13:30
Re: Air Cylinder
*clears throat*
But, of course, if you have a 3/2 valve, plumbing is a lot simpler and less prone to leaks.
Unread 01-03-2013, 13:42
Re: Air Cylinder
True.
