Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 14-02-2013, 07:03
Re: cRIO Drops connection after deploy
If this is repeatable, please bundle up your project folder and send it to NI support so that it can be investigated. I don't know of a bug or a reproducible set of steps that causes this behavior.
Greg McKaskle
Unread 19-02-2013, 22:58
WeRrobots WeRrobots is offline
FRC #4125
WeRrobots is an unknown quantity at this point
Hi. I'm from team 4125 and we are using also using a Lenovo Thinkpad. The same thing is happening with us. We've tried everything, with no luck. Maybe its the laptop? We're going to try to solve this problem by switching to the computer we used last year. We'll let you know how it goes...
Unread 28-02-2013, 12:57
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Despite many reformats and tweaks to our code, we continue to have the same issue as initially described. We will be taking a second cRIO to competition with us in the event we need to switch them.
Note, the issue is only present on one of our cRIOs. The issue does not appear on any of two other cRIO II's formatted with the 2013 LabVIEW firmware.
EDIT - @WeRrobots - I find it hard to believe the issue is stemming form the computer. The error is not reproducible on other cRIOs.
Unread 28-02-2013, 16:25
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
We had issues until we realized the new routers have QOS enabled on them, I would try turning QOS off on the router if you have not already.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 01-03-2013, 04:22
FRC #0023 (PNTA)
Rookie Year: 1620
Spencer - The symptoms were reproducible when connected directly to the cRIO via an ethernet cable, through the (2012 legal) dlink 1522 Rev A - wired and wireless, as well as through the (2013 legal) dlink 1522 Rev B - wired and wireless.
Unread 01-03-2013, 15:14
QOS is enabled on the radio when you use the Radio Setup tool. This is to mimic the bandwidth limits and QOS that is in place on the field. If you are having connection issues that are fixed by disabling QOS, this likely indicates that something you are doing is close to or exceeding the 7 MBps bandwidth limit. You should measure your bandwidth usage (see http://wpilib.screenstepslive.com/s/...ndwidth-usage).
Unread 03-03-2013, 11:21
Has anyone been able to send code and instructions to support so that the thread crash can be investigated?
Greg McKaskle
Unread 04-03-2013, 12:50
FRC #0023 (PNTA)
Rookie Year: 1620
I'll be able to zip up our code and send it to NI Support tonight.
Unread 07-03-2013, 07:49
RCB RCB is offline
AKA: Chris
FRC #3620 (Average Joes)
RCB is an unknown quantity at this point
Has anyone found out what is causing this problem? We are having the exact same issue.
