Go to Post PS: When/if it gets to be too easy to build a machine that can accomplish a recent/typical FRC game, then I suspect it will be time for someone to unveil a harder game. - gblake [more]
Unread 01-03-2013, 17:33
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
Encoder Problem.
So i am trying to get these encoders working,
http://www.grayhill.com/web1/images/...ncoder_63r.pdf
Connected pin 1(encoder) to DigitalI/O in digital sidecar Pin Signal 1
Connected pin 2(encoder) to DigitalI/O in digital sidecar Pin Power 1
Connected pin 3(encoder) to DigitalI/O in digital sidecar Pin Signal 2
Connected Pin 5(encoder) to DigitalI/O in digital sidecar Pin ground 3
and here is the java code i am using to test
 public void disabled(){
        Encoder TestEnc = new Encoder(2,1);
        TestEnc.reset();
        for(;;){
            System.out.println(TestEnc.get());
            Timer.delay(1);
i just keep getting a 0, no matter how much i rotate the encoder, both directions.
I tested the encoder with an arduino and it seems to work fine.
I switched to another digital sidecar and the problem persists.
any ideas?
cheers
arun
