Re: Talon Failure
Yes, we were driving CIM motors. We didn't bother with fans since the location we were testing was unheated. Ambient temperature was well below freezing.
Re: Talon Failure
Well there's your problem. Even if the environment around them is cold, you need to have some actual airflow in order to get rid of the heat.
Re: Talon Failure
Just to throw it out there...we have been running talons on our drivetrain (6cims) without fans and have yet to have any problems. We are huge fans of them so far.
Re: Talon Failure
Then you haven't been running them without fans after all.
Re: Talon Failure
I see what you did there...
Honestly OP, why put your $15,000 season at the mercy of $4.00 fans? Just put the things on. The draw of the Talons for us is the protected internals (maybe this season we'll make it through without losing 50% of our controllers for once...). Yet no amount of data could convince me to run the heavy load Talons without fans. |
Re: Talon Failure
Maybe if you're using a lot of talons then you could put the large KOP fan on the robot and angle it to blow over the talons
#7
Re: Talon Failure
When you are struggling with a bot that is almost 10lbs over the max, the concept of adding 10 fans which weigh in total well over 1lb is not well received. Last edited by Jim Wilks : 02-03-2013 at 17:56. |
#8
Re: Talon Failure
To reinforce the customer service of CTRE and Mike Copioli, we had a Talon fault out-of-box a week ago, and I have the replacement here in my hands already, even though I told him to "take his time" since this was a spare.
(On a related note: Also bought a Battery Beak from AM - wow, this thing is way cool!) It is really refreshing for a company to completely understand the FRC build season and its constraints, and ramp up their service to make life less stressful. Unlike DigiKey, which has yet to tell me what they are going to do about the 2 faulty Grayhill encoders I RMA'd to them. And I've been their customer for 30 years. |
#9
Re: Talon Failure
Just one more data point: Our 'bot has 8 Talons in it with 4 driving CIMs. None have fans. They survived the Granite State Regional quite nicely.
Now if we can figure out why a very lightly loaded window motor failed in the semis... |
