Go to Post I have a feeling this is going to be a really good year.:) - Richard Wallace [more]
  #31   Spotlight this post!
Unread 25-02-2013, 22:54
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: NEW: OPR Android App
Thanks for the app update. One suggestion I would make, though, for the next update would be to add a function to update all the regionals at once. Because how it is setup now, is that you have to go into each separate regional and update it one by one.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #32   Spotlight this post!
Unread 25-02-2013, 23:05
See earlier posts:
Originally Posted by stingray27 View Post
There is no refresh all button... this would cause the app to try and calculate all oprs for every team at every regional and I felt that the processing power would be too much on the phones.
Do not use matrix inversion. Instead, use Cholesky decomposition to factor the matrix. Read this thread, starting at post#36.
@stingray27:
That ought to be more than enough to process every match at every event, if you use the right matrix factoring algorithm.
  #33   Spotlight this post!
Unread 25-02-2013, 23:15
dodar's Avatar
See earlier posts:
Sorry, I probably should have specified. I meant for everything except OPR. Like team lists, match schedules, results, etc.
  #34   Spotlight this post!
Unread 01-03-2013, 11:03
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Sorry for all of the late updates, but OPR FIRST 1.2 is now available. Another update may be up shortly but I wanted to get another update out to make the app work. Look for it to become available on your phones shortly
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
  #35   Spotlight this post!
Unread 01-03-2013, 16:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by dtengineering View Post
I'd say that the "predictions" for upcoming match results will be a good way to determine when the data starts to become significant. It would be great to have an analysis of what fraction of the predictions are correct... it would be an excellent way to show at what point the OPRs become an effective indicator of match outcome.
But OPRs and scouting reports are always useful, if only for entertainment's sake!
Jason
Older versions of OPRNet had a "self-check" mode for their predictor - if a regional was complete when someone asked for a prediction, it would tell you how good the predictions would have been if it had made them with the data available after each match. So it would say:
"After match 59, the predictions for matches 60-80 would have been 65% correct"
"After match 60, the predictions for matches 61-80 would have been 64% correct" (it varied a lot)
Generally what I found was that on friday night, saturday predictions based on the sum of OPRs for each alliance were 60-70% correct, which is obviously way better than a coin toss. This depends on the game though - OPR is better or worse depending on what the game is like. See the 1-hour mark of Karthik's presentation at champs last year for more details.
Post-event (aka once you know all the data) it was 80ish% correct, but that's a fairly worthless stat: once the event is over, anyone can get 100% of predictions correct!
  #36   Spotlight this post!
Unread 01-03-2013, 18:44
Racer26 Racer26 is offline
Am I the only one finding that this app straight up doesn't work? I couldn't pull anything for BAE all day, while FRC Spyder was working fine.
  #37   Spotlight this post!
Unread 01-03-2013, 19:28
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Bae results are working with todays update.
Thanks!
  #38   Spotlight this post!
Unread 01-03-2013, 23:35
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is on a distinguished road
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
I'm not getting anything from the 'Team Statistics' choice for the Kettering University District event and even though they and BAE's Granite State Regional have played the same number of matches so far (52 through Friday night), BAE does give me OPR rankings. I also don't get any data for the other District event this week (Traverse City) even though I currently get OPR data for every Regional that played matches today.
Is there an issue with the way the districts are set up, either in the code or real life, that's causing this?
  #39   Spotlight this post!
Unread 01-03-2013, 23:38
stingray27's Avatar
AKA: Michael Ray
You beat me to it I was just typing this up when you replied. Check for an update within the hour. Here is what I was typing though:
OPR FIRST 1.3 is now available. Plenty of bugs were fixed today - so I apologize for all of the inconvenience. Nice thing is, I believe I updated all of my bugs and it should work fairly well now. If I notice any others, I will update them as soon as possible. The revision from 1.2 to 1.3 fixed:
- Now can display match stats from District events (Ie Kettering and Traverse City). The district system made parsing different but I fixed it.
- The awards page didnt work but now does
Now on to functionality! Should be coming up shortly (the new cool functions ) but give me some time on that. Thanks!
Michael Ray
Team RUSH 27
  #40   Spotlight this post!
Unread 01-03-2013, 23:43
AKA: Raa'Shaun H.
Thanks for the update, I didn't actually get 1.2 until about 2 hours ago so I wasn't sure what the issue was. I guess I'll be waiting until morning for the 1.3 update though. Google Play doesn't show it for me on my computer or my phone yet. Thanks for the update ^_^
  #41   Spotlight this post!
Unread 02-03-2013, 01:22
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
I cannot get mine to update the Hub City tournament all day. I am trying tonight and still says update unsuccessful. I have updated to the latest version.
Norman
FRC 2468 Team Lead 2008 - Present
Win The Day!
  #42   Spotlight this post!
Unread 02-03-2013, 01:35
HayWire1569 HayWire1569 is offline
FRC #1569
HayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of lightHayWire1569 is a glorious beacon of light
Is there anything this awesome for apple products?
  #43   Spotlight this post!
Unread 02-03-2013, 01:55
REVving up for a new season
FRC #2848 (All-sparks)
Norman
ditto.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #44   Spotlight this post!
Unread 02-03-2013, 03:48
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Originally Posted by engunneer View Post
in 2009, I ran OPR after the match schedule came out at CMP for my field (Galileo), and it said we'd seed 3rd after 111 and 67. I had to go back an inspect the match schedule to verify, but we were partnered with 67 and 11 in a match each, and never faced them in quals. I swear we had the luckiest match schedule of the field. Ended up seeding 2nd after HOT had a freak loss towards the end of quals. 111 picked 67 and went all the way, IIRC.
OPR data after an event is certainly useful.
Yes, i remember that match they lost. We were their partner.
  #45   Spotlight this post!
Unread 02-03-2013, 07:01
stingray27's Avatar
AKA: Michael Ray
Originally Posted by Greg Needel View Post
ditto.
Yep. Thank you. Bug is noted and I will take a look at it as soon as possible. Looks like when I fixed the mi districts I messed up hub city...
Michael Ray
Team RUSH 27
