Re: Encoder getRate question
I did not receive the gear ratio from the person who was in charge of the shooter, but it is a higher teeth count on the motor and a lower teeth count for the wheel. And yes, this is for the shooter. Also the encoder wheel has 250 ticks.
On encoders for shooting wheels, you may wish to watch out for the maximum RPM the encoder can handle. There are both electrical and physical issues there.
You can also approach the granularity of the VxWorks timer, which I believe has a resolution of 6 us. Since GetRate() gives you the inverse of the time between the last two ticks, with a resolution of about 6 us, this caused us some issues with oscillation between two substantially different returned values for RPS. Using the FPGA with the ring buffer may help with this, but we opted for the x1 resolution. |
See the attached example calculation of a 250 CPR encoder set up this way and spinning at 5000 rpm, showing the effect of the 6us polling period of the FPGA when the ring buffer is set to 125 samples (1/2 of a revolution). Quote:
The reason we had quad-encoding on this encoder was that at one point we were going to reload discs back through the barrel of the gun, causing us to run the motors backwards and wanting to be sure we knew they were running backwards. Also, I seem to recall that the PID classes wanted an Encoder and would not accept a Counter. I may be wrong about that. Quote:
#7
The PIDController class only needs a PIDSource and PIDOutput. Counter does not implement PIDSource, but you could always extend it and implement PIDSource.
#8
A made a modified Counter class, to be used with PIDController and has 120 samples to average. It works wonderful. Thank you Ether.
#10
Would you be willing to post your modified Counter class? It would be a service to the FRC community. There are other teams/individuals who need some help figuring out how to do this. Last edited by Ether : 13-03-2013 at 15:01. Reason: typo |
#11
In case anyone else was looking for a source code example...
Looks like Joe Ross posted a patch to the Encoder and Counter classes for Java. http://firstforge.wpi.edu/sf/go/artf...v=1&_pagenum=1 |
