Go to Post Woody is wearing flippers... 2014 WATER GAME! - Team23pitboss [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #121   Spotlight this post!
Unread 01-03-2013, 14:27
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Re: Alternate GCC Toolchain
Does anyone know if there's support for C++11's new math functions, namely copysign()? It wasn't working for me, but that could just be on my end.
  #122   Spotlight this post!
Unread 01-03-2013, 19:47
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
There should be. Again, there used to be a bug with c++11 support, which should be fixed when I release the new packages and builds (hopefully very soon). If you can paste the errors you are getting and the output of make VERBOSE=1 I can see if you are affected by this bug and the resolution.
FRC 612 '12
USNA '16
  #123   Spotlight this post!
Unread 01-03-2013, 22:06
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
@wlmeng11 I've just built it successfully in a Ubuntu 12.04 64.
The "--64" indicates 64 bit, and I'm pretty sure it should be running /user/powerpc-wrs-vxworks/bin/powerpc-wrs-vxworks-as not /user/powerpc-wrs-vxworks/bin/as .
Are you sure you passed --target to both binutils & gcc's configure?
  #124   Spotlight this post!
Unread 01-03-2013, 23:43
/usr/bin/powerpc-wrs-vxworks-as should be a hard link to /usr/powerpc-wrs-vxworks/bin/as
Binutils is fine - as isn't supposed to take a --64 argument AFAIK. Can you post your config.log?
FRC 612 '12
USNA '16
  #125   Spotlight this post!
Unread 02-03-2013, 00:07
wlmeng11's Avatar
wlmeng11 wlmeng11 is offline
FRC #0008 (Paly Vikings)
wlmeng11 will become famous soon enough
I'm using the commands from the first post for configure.
Which version of GCC are you using and where did you get it? (official repos, PPA, or source)
  #126   Spotlight this post!
Unread 02-03-2013, 01:13
Programming Lead
AKA: Kunkel
The complete output of make VERBOSE=1 is as follows:
/usr/bin/cmake -H/home/maraschinopanda/src/422-robot-2013 -B/home/maraschinopanda/src/422-robot-2013 --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /home/maraschinopanda/src/422-robot-2013/CMakeFiles /home/maraschinopanda/src/422-robot-2013/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/home/maraschinopanda/src/422-robot-2013'
make -f CMakeFiles/bin/422-robot-2013.dir/build.make CMakeFiles/bin/422-robot-2013.dir/depend
make[2]: Entering directory `/home/maraschinopanda/src/422-robot-2013'
cd /home/maraschinopanda/src/422-robot-2013 && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/maraschinopanda/src/422-robot-2013 /home/maraschinopanda/src/422-robot-2013 /home/maraschinopanda/src/422-robot-2013 /home/maraschinopanda/src/422-robot-2013 /home/maraschinopanda/src/422-robot-2013/CMakeFiles/bin/422-robot-2013.dir/DependInfo.cmake --color=
make[2]: Leaving directory `/home/maraschinopanda/src/422-robot-2013'
make -f CMakeFiles/bin/422-robot-2013.dir/build.make CMakeFiles/bin/422-robot-2013.dir/build
/usr/bin/cmake -E cmake_progress_report /home/maraschinopanda/src/422-robot-2013/CMakeFiles 20
[ 5%] Building CXX object CMakeFiles/bin/422-robot-2013.dir/Commands/CheesyDrive.cpp.obj
/usr/local/bin/powerpc-wrs-vxworks-g++ -c /home/maraschinopanda/src/422-robot-2013/Commands/CheesyDrive.cpp -o CMakeFiles/bin/422-robot-2013.dir/Commands/CheesyDrive.cpp.obj -isystem /usr/local/powerpc-wrs-vxworks/include/WPILib -mcpu=603 -mstrict-align -mlongcall -nostdlib -Wall -DCPU=PPC603 -DTOOL_FAMILY=gnu -DTOOL=gnu -D_WRS_KERNEL
/home/maraschinopanda/src/422-robot-2013/Commands/CheesyDrive.cpp: In member function 'float CheesyDrive::truncateOutOfBounds(float)':
/home/maraschinopanda/src/422-robot-2013/Commands/CheesyDrive.cpp:113:35: error: 'copysign' was not declared in this scope
newValue = copysign( 1.0, value );
make[2]: *** [CMakeFiles/bin/422-robot-2013.dir/Commands/CheesyDrive.cpp.obj] Error 1
make[1]: *** [CMakeFiles/bin/422-robot-2013.dir/all] Error 2
make[1]: Leaving directory `/home/maraschinopanda/src/422-robot-2013'
make: *** [all] Error 2
I've not been using the binaries, by the way, so fixing them won't fix my problem. (Woo Gentoo!) But it's possible we made the same mistake. My version of GCC is 4.8.0
  #127   Spotlight this post!
Unread 02-03-2013, 01:50
AKA: Cody Schafer
I've been building either the gcc-master tarballs from github (ie: latest snapshot), or using the date marked snapshots from the gcc mirrors.
ie: all source, all upstream.
  #128   Spotlight this post!
Unread 02-03-2013, 12:22
If you go to a clean build directory and run:
$ frcmake $SRCDIR -DCMAKE_CXX_FLAGS='-std=c++11 -fpermissive'
Then it should work. The use of -fpermissive is evil, but I seem to remember it being necessary, I think with WPILib doing something that is officially deprecated in C++11...
FRC 612 '12
USNA '16
  #129   Spotlight this post!
Unread 02-03-2013, 15:13
wlmeng11's Avatar
Are you also building all the other libraries from source? (gmp, mpfr, and mpc)
  #130   Spotlight this post!
Unread 02-03-2013, 15:16
AKA: Cody Schafer
@wlmeng11
yes. See the build script I use, more info in this post back on page 7:
http://www.chiefdelphi.com/forums/sh...1&postcount=86
  #131   Spotlight this post!
Unread 04-03-2013, 07:52
UPDATE:
I've figured out how to get the repository to work, and I'm in the free tier for amazon s3. Thus, here's the link to a new FirstForge wiki page on how to set it up:
http://firstforge.wpi.edu/sf/wiki/do.../BinaryInstall
Currently, I only have packages for debian wheezy. I don't know if they will be binary-compatible with Ubuntu. The only binary library dependencies are libc and zlib, which are both pretty good with compatibility, bu you never know...
There's also instructions on how to build the packages here:
http://firstforge.wpi.edu/sf/wiki/do.../ManualInstall
I'll be putting more instructions on how to compile manually from source (for other distributions) on that last page. Hopefully I should finish updating soon!
FRC 612 '12
USNA '16
  #132   Spotlight this post!
Unread 04-03-2013, 15:09
wlmeng11's Avatar
Originally Posted by rbmj View Post
UPDATE:
Thank you!
The PPA worked for me on Ubuntu 12.04.
  #133   Spotlight this post!
Unread 05-03-2013, 19:02
The new required C++ update to WPILib has been incorporated into the git repo of WPILib and the builds have been uploaded. Let me know if you have any issues. For anyone using the repo, a standard aptitude update && aptitude upgrade should do the trick.
As always, let me know of any issues that arise.
FRC 612 '12
USNA '16
  #134   Spotlight this post!
Unread 08-03-2013, 18:08
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
I made a PKGBUILD for the 64-bit version of this toolchain. It is available on the AUR. If you have an AUR package installer (like yaourt), you can install it by simply doing:
yaourt -S vxworks-gcc-toolchain-bin
P.S: This is using binutils and GCC 4.8 snapshots from the 20th of January. I'm working on the i686 binary release and a source release
Alex Brinister
  #135   Spotlight this post!
Unread 09-03-2013, 09:56
Alex Brinister
Thanks! I'll update the wiki, which is finally getting semi-complete:
http://firstforge.wpi.edu/sf/go/proj..._toochain/wiki
FRC 612 '12
USNA '16
